Thread: How to install TDCRacing FWI.
Results 1 to 8 of 8
  1. #1 How to install TDCRacing FWI.
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    Since there have been no instructions up to this point, I thought that I would document my installation for everyone here and then also provide a PDF version of the following to be placed on the TDCRacing web site for download. Oh, and yes, I know that my car was (still is actually) very dirty.
    ---------Start of "How To"---------
    How to install a TDCRacing Fenderwell Intake (FWI)
    Welcome To TDC Racing
    Last updated August 16, 2009 – NickBuol
    Before venturing into the installation of any sort of intake or automotive modification, be sure that you are fully aware of what you are doing, as well as understanding the workings of the parts being modified. Take your time and do it right the first time so that you can get out and reap the rewards of your efforts.
    For the TDC Racing FWI, you will need several tools that are commonly found in any decent tool set. If you need these tools for this install, it is advised to get them rather than borrow them as you may find that you need them later anyway.
    Tools Required:
    Ratchet (3/8” or 1/2” – just be sure to get correct matching sockets)
    Sockets: 1/2” (13mm will also work), 8mm, and 10mm
    Flathead screwdriver
    Power screwdriver with Phillips bit (for putting self-tapping screws in)
    For this installation, we are installing the TDC Racing FWI on a 2000 Pontiac Grand Prix GTP. Installation on your vehicle may vary, but this will give you a general idea of the installation process. Here is a picture of the intake painted in hi-temp black with the K&N filter. Notice the IAT hole and grommet marked in yellow below.
    [Picture in next post due to site limitations]
    So here is our 2000 GTP before any changes. We will basically be removing the equipment marked below.
    1) Use the 1/2" socket to remove the 3 bolts holding the cross-brace in place. Set parts aside.
    2) Use the 10mm socket to remove the two bolts holding the headlight in place, disconnect the wireing harness plug, and carefully remove the headlight by sliding it outward, and in the case of the 2000 GTP, to the right as well. Set parts aside.
    Below is a picture from the front showing the stock intake opening on the left, the headlight plug on the bottom, and a support bracket on the right that we will need to get out of the way.
    3) Using a 10mm socket, remove the bottom bolt (shown below) from the fender brace. Once removed, slightly bend the bracket outward and to make room for the intake pipe. Put the bolt back in its socket or put it in a safe place in case you ever decide to go back to stock later on.
    4) Use a flat head screwdriver and loosen the clamp around the stock intake hose and disconnect it from the air filter box.
    5) Next, use the 8mm socket to release the two screws on top on the stock air filter box. Remove the inner half of the filter box as shown below. You can now also see the PCM in the bottom of the filter box. We will need to move that carefully out of the way.
    6) Remove the outer half of the filter box.
    Below is a closer picture of the PCM with the air filter box completely removed.
    7) Go ahead and VERY carefully remove the IAT sensor from the intake hose and the remove the hose.
    Below is a picture of the IAT and hose removed. This is where the intake will connect up using the silicone connector and two clamps.
    8) Carefully take the intake tube and place it through the opening leading to the front fender.
    Below is a picture showing the intake tube inside the fender and the fender bracket pushed out of the way.
    9) Place the cone filter securely on the end of the intake tube and tighten down the included clamp using an 8mm socket. Here is a picture of the intake installed inside the fender.
    10) Using the provided clamps and silicone coupler, connect the other end of the intake to the engine using an 8mm socket to tighten the clamps. VERY CAREFULLY put the IAT sensor into the grommet of the intake.
    11) Using the power screwdriver and the included self-tapping screws, secure the triangular heat panel to the inside of the vehicle. This provides a barrier between your hot engine compartment and the intake end. It also helps to prevent the intake from moving.
    12) Using whatever method you like, secure the PCM to the body of the car. For this install zip ties (red ones) were used to hold it in place.
    13) Reinstall the cross brace with the three 1/2" bolts.
    14) Rubber “feet” were placed under the PCM after it was strapped down to prevent rocking and movement, as well as to provide a cushion for the PCM. Below is a picture of the “feet” that were used for this install.
    Below is the finished install and the car is ready for a test run (and a good wash). The vehicle now has a much more noticeable supercharger “whine” meaning that your supercharger is finally able to breathe. You may also notice what has been called the sound of a “breathing dragon” when the vehicle is first started up and the engine is cold. This is caused by the normal operation of the IAC and goes away after a minimal amount of driving. Enjoy the intake and boost in performance. If you have any questions, just visit the Top Dead Center Racing website at Welcome To TDC Racing or call (478) 225-5977.
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  2. #2 Re: How to install TDCRacing FWI.
    Apr 2008
    Marion, Iowa
    Here are the two pictures removed from the above post due to the forum limit of 10 pictures maximum per post.
    First the intake with filter (IAT grommet marked in yellow). I sanded, primed, and painted this myself, but TDCRacing offers painting services too.
    And here is the final engine bay shot of my dirty car as what would be at the very end of the "How To".
  3. #3 Re: How to install TDCRacing FWI.
    chicago
    can you take pic of the block off plate and what method did you use to tack it down? you think there's room for a 9" cone to fit in there?
  4. #4 Re: How to install TDCRacing FWI.
    Apr 2008
    Marion, Iowa
    The block off plate just gets screwed down with the self-tapping screws. Yes, that means putting a couple holes into the body of the vehicle. You could try something like commercial grade Velcro, but with all of the heat, I have no idea what would happen. Could turn to goo and just be a mess.
    As for the 9" filter, I've been told that one will fit, but my personal experience with this install would say that it would take a bit of work to get it in there. The fender well isn't a huge space to put one in, but like I said, I was told that one would fit.
  5. #5 Re: How to install TDCRacing FWI.
    Apr 2008
    Marion, Iowa
    Wow. I still can't believe that I went through that effort just to have TDC Racing so "south" on us... What a bummer.
  6. #6 Re: How to install TDCRacing FWI.
    Moore, Oklahoma
    **** happens...
    I'm still shocked he flaked out like he did, can't trust anyone I guess...
    Shawn W. Larsen
  7. #7 Re: How to install TDCRacing FWI.
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    wow, at least your iat hole is in the correct spot..mine is down under the first bend from tb, facing almost damn straight down...nice huh?
  8. #8 Re: How to install TDCRacing FWI.
    Quote Originally Posted by popeyenate View Post
    I didn't get a hole for mine. Just drilled a hole in the adapter between the TB and intake.
  1. 04+ HUD Install
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-06-2012, 02:25 PM
  2. L36 LIM Install
    By 01gtspecial in forum General Tech Discussion
    Last Post: 07-08-2009, 10:29 AM
  3. HELP!!! TDCRacing FWI install...
    By popeyenate in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-25-2009, 07:35 PM
  4. please help!!! cai install
    By BIGTMANE in forum General Tech Discussion
    Last Post: 06-05-2009, 05:27 PM
  5. need help with LOC install!!!
    By riceburner in forum Audio, Security & Visual Electronics
    Last Post: 11-09-2008, 04:00 PM
