I did this write up simply because i was in need of a new corners light so figured i would have nothing to lose if i messed anything up, but DO THIS MOD AT YOUR OWN RISK I WILL NOT BE HELD RESPONSIBLE IF YOU MESS YOUR CORNERS LIGHTS UP. Ok now that i got that out of the way lets begin.
1. Remove your corner light you can do this by removing the screw, and then there are 2 bulbs that you need to take out.
2.Set your Oven at 300-305 degrees and let it Pre-heat if needed
3.Set your corner light on some kind of pan
4.Place it in the oven ONLY LET SIT IN OVEN OF 3 MINS MAX
5.Remove from oven, then wait about 1 min and slowly start prying the lens off.
6. Once you get the lens off the Amber piece will just come right off
7.Put the lens back on but be sure to put some sealant on them so they will not leak.
8.Put back on car and enjoy the beauty of them
