Thread: Removing gaskets off soft metal (3M Roloc)
Results 1 to 20 of 22
  1. #1 Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    Made a short little video (using a fellow members GenV case as the model) to show you what I use to safely and correctly remove gaskets off non ferrous metals.
    YouTube - 3M Roloc
    For other metals, such as steel and iron, you would use the GREEN colored bristle pad from 3M.
    No need to invest in the white ones, the other two will do all the jobs nicely for almost any application you will ever need them to.
    3M? Roloc? Bristle Discs
    ~F~
  2. #2 Re: Removing gaskets off soft metal (3M Roloc)
    Feb 2008
    San Diego, CA
    x2
    Roloc bristle discs are great. I have used them for removing remnants of gasket and/or RTV off S/C, LIM, heads and block.
    They don't leave fibers and residue like Scotchbrite, and they don't remove metal or round off sharp sealing edges like an orbital sander.
  3. #3 Re: Removing gaskets off soft metal (3M Roloc)
    Moore, Oklahoma
    Nice, way better than scotch brite! I'm gonna have to go to harber frieght one day and look for tha pack you got farnsworth. You don't have an item # by chance do ya? I could use this for my tool box...
    Shawn W. Larsen
  4. #4 Re: Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    Quote Originally Posted by Iron Indian View Post
    Harbor Freight: Item #94196 "Surface CO" Price $12.99
    Its very handy to have...101 uses for this small package. I bought it JUST for this video, I have only been using the 3M bristle pads since then.
    ~F~
  5. #5 Re: Removing gaskets off soft metal (3M Roloc)
    Jersey
    I carefully used a razor blade
    16' wrx sti- stock
  6. #6 Re: Removing gaskets off soft metal (3M Roloc)
    Oklahoma
    Nice video Farns. I already have the harbor freight pack you have. I just need to shop for some Roloc discs now.
  7. #7 Re: Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    Quote Originally Posted by 99prixgt View Post
    Not saying you cant use them, they work yes, but there is a better, safer way.
    I just kept getting cores sent in, or cases sent in for work where somebody had used a gasket scraper, or a razor blade obviously, and just hacked the crap out of em. Looked like some were drug behind a car on a gravel road. Its sad to see, so made a video showing that there is a much better safer way to do it, for those who are not skilled enough to use a blade.
    Not saying you HAVE to do this or use this method, for every job, there is always another way to go about doing it.
    ~F~
  8. #8 Re: Removing gaskets off soft metal (3M Roloc)
    Jersey
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    Agreed. Im glad you posted this method, I will definitely try using your method next time . It was extremely tedious using a razor blade, I had to keep changing blades every 5 seconds because they would dull and get jagged, your method is much more care-free.
    16' wrx sti- stock
  9. #9 Re: Removing gaskets off soft metal (3M Roloc)
    Los Angeles
    I thought there was a TSB under the TSB write up which discourages using these discs?
  10. #10 Re: Removing gaskets off soft metal (3M Roloc)
    Aug 2008
    Long Island, New York
    good video! looks good
  11. #11 Re: Removing gaskets off soft metal (3M Roloc)
    By chance did you still have a copy of this video which could be hosted again?
  12. #12 Re: Removing gaskets off soft metal (3M Roloc)
    Charles City, IA
    I have a few rolec disks at home that I could do a little write up.
    SMGPFC Two Nipple General
  13. #13 Re: Removing gaskets off soft metal (3M Roloc)
    i have easy access to the green ones, but the question is, whats safe for aluminum?
  14. #14 Re: Removing gaskets off soft metal (3M Roloc)
    Charles City, IA
    yellow-aluminum
    green- cast
    I just use yellow on everything works fine.
  15. #15 Re: Removing gaskets off soft metal (3M Roloc)
    Thanks!
  16. #16 Re: Removing gaskets off soft metal (3M Roloc)
    Charles City, IA
    I will make a vid/write up tomorrow.
  17. #17 Re: Removing gaskets off soft metal (3M Roloc)
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    green scotch pads ftw. Cleans mine up every time with alitte elbow grease and some spray cleaner like carb cleaner
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  18. #18 Re: Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    Here ya go, sorry for the late reply. Somebody else uploaded my video again after I deleted them all.
    YouTube - Honda-Tech: How to Remove tough gaskets
    Yes, green is for ferrous metals, and yellow for non ferrous metals. They also have white, which is a super heavy duty bristle pad that will take almost anything off, including tattoos if you wish. LOL
    Light pressure when you work, and keep the RPM's of the die-grinder (or power drill, what ever you wish to use) at a medium level, which will allow the pad to do its job, and not trash it, or wear it out quickly.
    ~F~
  19. #19 Re: Removing gaskets off soft metal (3M Roloc)
    Charles City, IA
    Great video, it wont jack your **** up. I will also stress not to use the scotch brite style pads for anything on the engine. They will leave tons of fibers behind.
  20. #20 Re: Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    X2, seen it first hand. Unless your doing it on parts OFF the engine, and they are going to be really cleaned out after wards before they are reinstalled, keep scotch brite/fiber pads far away from a open engine.
    ~F~
  1. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
  2. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  3. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
  4. Metal Shavings
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-02-2008, 11:53 AM
  5. LS1/LS2 metal oil cap overlay
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:57 AM
