Thread: How to replace front hubs
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 108
  1. #61 Re: How to replace front hubs
    most of the time if they resist resulting in around 25 ft lbs of torque they're fine.
  2. #62 Re: How to replace front hubs
    SE Level Member mikeplan14's Avatar
    Apr 2011
    Indiana
    nice write-up!
  3. #63 Re: How to replace front hubs
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Looks like I'm tackling this on Saturday - my passenger hub went bad (had 170K miles on it). Ordered a Timken from Rock Auto.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  4. #64 Re: How to replace front hubs
    South Jordan, UT
    Replaced the pass hub yesterday and that wasn't too bad at all. The hub bolts came out quite easily fortunately. The hardest ones to get loose were the caliper bracket bolts. A word of advice in case it hasn't been mentioned yet is to remove the lower caliper bracket bolt first - that way the caliper won't try and spin off on you.
  5. #65 Re: How to replace front hubs
    Jul 2012
    Buffalo NY
    The 3rd picture shows a bracket below the hub. What is its use. On both sides of my car it is rubbing against the rotor and making a noise.
  6. #66 Re: How to replace front hubs
    GT Level Member Utter99's Avatar
    Warsaw indiana
    on my rear hubs i just put my doughnut tire on and kicked it a few times and it broke the hub loose so much easier then pounding it off
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  7. #67 Re: How to replace front hubs
    Northern IL
    Quote Originally Posted by Utter99 View Post
    Wonder if this will work for the front? I will be doing this job in the next few weeks.
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by veener79 View Post
    Yea it should work the same. Personally never done it that way but a little pb blaster and a slide hammer and the thing comes out easily. The tire thing and the slide hammer are sorta the same general ideas.
    Sent from my DROID RAZR using Tapatalk 2
  9. #69 Re: How to replace front hubs
    Jul 2012
    Utah
    Tried to replace my front hub assembly today. I was able to get everything loose but the three hub bolts. All three started to round off so I just called it quits. Any hints on getting these bolts off? I've got them soaked with PB Blaster, but thats a pretty long bolt to get soaked. Any suggestions welcomed.
  10. #70 Re: How to replace front hubs
    Apr 2012
    Goderich, Ontario
    Turn the steering wheel to the left and then to the right and use a 3/8 drive socket with an extension. Just did this today too.
    -Paul Walker
  11. #71 Re: How to replace front hubs
    Jul 2012
    Utah
    Smoke14, thats just what I did. No luck at all. I quit before the bolts were rounded completely off. I guess I'll take it to the shop and let them have a go at it.
  12. #72 Re: How to replace front hubs
    Apr 2012
    Goderich, Ontario
    Soak everything in WD-40. Keep the socket square and the bolts shouldn't round off. Patience helps too. I had to use a pipe on my ratchet to break them loose so I used anti-sieze when I put them back in.
    -Paul Walker
  13. #73 Re: How to replace front hubs
    if you take the 2 strut bolts out, and pop the tie rod out of the knuckle, you can push the axle out of the hub, and then have a clear shot at these 3 bolts.
  14. #74 Re: How to replace front hubs
    Northern IL
    Quote Originally Posted by marines542 View Post
    Did not think of a slid hammer. I have a nice set this one
    OTC 7948 10-Way Slide Hammer Puller Set with Storage Case : Amazon.com : Automotive
    Hope that will work well.
    Good to know. I also have to replace the tie-rod ends. That could make it a lot easier. Going to have to get an alignment after the job either way.
  15. #75 Re: How to replace front hubs
    Northern IL
    Well this morning I replaced both hubs and both tie rod ends in about 3 hours. The car is now over for an alignment. I would recommend if you can get the tie rods off. It makes it very easy move things around.
    The passenger side was so easy. The hub fell right out I was shocked. Mostly because I live in the Chicago area and all the salt.
    The drivers side was a lot bigger pain. I had to cut off the end of the bolt to get tie rod off. I could not get the rotor off after about 10min of hitting it. So I just left it on till I get the hub off and then hit the hub against the floor and it came right off.
    Also the hub did not want to come out. I used my slid hammer and it came right off after 3 hits. I would recommend a slid hammer for this any time!
  16. #76 Re: How to replace front hubs
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    I've done hubs many times on 3 different cars now, and the easiest way to get the hubs off after the bolts are out is demonstrated on the 1aauto video...put a screwdriver on the back of the hub, and bash the hell out of it with a hammer. Sometimes the hub will separate from the metal sleeve against the knuckle, but that's pretty easy to dig out with a screwdriver/vice grips (bend it out with the screwdriver, twist/pull with the grips). I also use ALOT of PB blaster for this job here in the midwest.
    I've never rounded out a bolt, and like was said earlier - be patient with these things. Worst situation I've had with it is the top bolt...always seems the clamp on the axle boot is right in front of it and gives me one more thing to go around, but PB blaster, extensions, and alot of patience works well.
    I've never replaced the hub bolts either, BTW, and never had issues. I've done hubs on my wifes Montana twice now (170,000 miles, 11 years old), and don't have issues with the bolts coming loose.
  17. #77 Re: How to replace front hubs
    Tricks: The bolts are closer tolderance to 1/2" than 13mm. A 1/2" typically keeps you from rounding. Once the bolts are off and you've free'd the axle from the hub, I beat the hub with the BFH.
  18. #78 Re: How to replace front hubs
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Nice write up. Thanks for sharing
  19. #79 Re: How to replace front hubs
    Nov 2011
    NY
    Sorry to revive an older thread, but its on topic, lol...
    replaced passenger front hub today, all went well, easy peasy... Problem was once all put together, the ABS/TCS was off... Dead on arrival hub? Moog hub from Rockauto, bought two so will swap it out tomorrow with the other, just wondering if anyone else has had this issue.
    Thanks
  20. #80 Re: How to replace front hubs
    did you have it scanned so you know for sure what was causing the abs light?
    maybe theres another hub to be changed.
  1. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  2. Axles, hubs and Halos - oh my!
    By MnRedGP in forum General Tech Discussion
    Last Post: 02-08-2009, 02:08 PM
  3. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  4. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
  5. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
