Thread: tsb on the grand prixs [*]
Results 1 to 15 of 15
  1. #1 tsb on the grand prixs [*]
    GT Level Member bad1999gtp's Avatar
    eau claire, wisconsin
    These Technical Service Bulletin's (TSB's) have been added to the How To section and can be found HERE.
    i will list them all as i get them there is alot of them and this may be of some help to someone. if you all think i should keep them in one window just let me know so i do not make a mess out of these
    ported m90,ported lower,160 tstat,headers,3in dp,cat&resi delete,flowmaster 44's,103's,zzp ic,42.5 inj,N*,3.4 pulley,cust. pcm,ported heads,cai,drilled&slotted rotors,gmpp sway bars
  2. #2 Re: tsb on the grand prixs
    Oklahoma
    You're doing fine, this is great stuff. Keep up the good work. We'll try and get this moved over to the How To section in the near future.
  3. #3 Re: tsb on the grand prixs
    thanks guys i will do what i can and you guys just set it up anyways you all would like
  4. #4 Re: tsb on the grand prixs
    i will post more tomorrow.
  5. #5 Re: tsb on the grand prixs
    Oklahoma
    Awesome stuff bud, keep up the good work and thanks for all the great information.
  6. #6 Re: tsb on the grand prixs
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    x2!
    SS-- are these going to be cataloged in PDF or word doc form? having them all in posts might make it a bit more difficult to keep organized/find?
  7. #7 Re: tsb on the grand prixs
    Oklahoma
    Quote Originally Posted by Toasty View Post
    I was thinking about doing that very thing as I saw the number of items he was posting. So I will probably take on that task once all of them are posted up. Posting them here makes them searchable so it is a very good thing in that respect, but we will get them over to the how to section so they can be easily downloaded as well.
  8. #8 Re: tsb on the grand prixs
    yeah i have about 30 more for the '99 model year but it seems that it is also covering all the years from 1999-2002 model year but if you would like i could post them for all model years. and if you want tsb's for an other model posted just let me know. give me a make and model and i will ge those posted to it will take a bit but i can do it in my spare time.
  9. #9 Re: tsb on the grand prixs
    Saraland Alabama
    I'd love to see the ones for '97, but may be scared by the sheer number
  10. #10 Re: tsb on the grand prixs
    GTX Level Member webracin's Avatar
    Arkansas
    I have started to convert each TSB into PDF format. What I will do is once I have them posted on in the HOW TO section, I will delete them from here.....Just keep adding them and I will keep converting and adding to the HOW TO section.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  11. #11 Re: tsb on the grand prixs
    ok well i will keep adding
  12. #12 Re: tsb on the grand prixs
    just remember that the ones i am posting right now are from what i got when i did a '99 so like i was saying if you want me to post them for all years you need to let me know.
  13. #13 Re: tsb on the grand prixs
    be back later with the rest of them for the '99 model year then i will start on the '97 model year and go up from there for the grand prix. if you want them for the impala or regal you will have to let me know or any other model
  14. #14 Re: tsb on the grand prixs [*]
    Feb 2008
    Innisfil,Ont
    THank you,great info,since my new 07 is going back to dealership for condensation in the headlamps assemblies.
  15. #15 Re: tsb on the grand prixs [*]
    Donating Users moddman's Avatar
    Midwest
    Since the TSB in link don't work. Here is a good share.https://www.automd.com/tsb/pontiac_m/grand-prix_mm/
  1. my grand prix
    By grandprix0429 in forum Off Topic Discussion
    Last Post: 06-22-2010, 08:07 AM
  2. Grand Prix pics
    By Cronik in forum Off Topic Discussion
    Last Post: 06-22-2008, 08:27 PM
  3. Grand Prix DTC Troubleshooting [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2008, 02:07 AM
  4. Largest Grand Prix Club
    By Rocket468 in forum Off Topic Discussion
    Last Post: 01-03-2008, 08:48 AM
  5. Grand prix's
    By UR LOSN in forum Forum Bugs/Suggestions
    Last Post: 12-17-2007, 07:10 AM
