Thread: Change Vin / Serial Number of Bin File
Results 1 to 8 of 8
  1. #1 Change Vin / Serial Number of Bin File
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Scotty and I were having some trouble changing Vin / Serial Number info of certain bins from certain later model year PCMs. Tiny Tuner did not seem capable of making the changes. I used a free hex editor to get around this issue.
    1. Download hex editor and install:
    https://mh-nexus.de/en/hxd/
    2. Open the hex editor program you just installed
    3. Use File--> Open and select the Bin you want to modify
    When you open it, it will look like a crazy mass of numbers. No fear! It's going to be really simple.
    4. Click the "search" menu, then click "replace"
    5. In the "Search for" box, enter the vin number that is already on the bin file.
    6. In the "Replace with" box, enter the vin number you would like to put on the bin.
    7. Click the "Replace all" button
    8. Repeat steps 4-7 for the Serial Number if you need to.
    9. Use File ---> Save to save your changes.
    Bin is now successfully changed.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Change Vin / Serial Number of Bin File
    subbed......
  3. #3 Re: Change Vin / Serial Number of Bin File
    Mar 2016
    Monroe louisiana
    does this still work?
  4. #4 Re: Change Vin / Serial Number of Bin File
    yes
  5. #5 Re: Change Vin / Serial Number of Bin File
    Mar 2016
    Monroe louisiana
    Oh ok I just seem in another thread a work around. Have to use old version
    Sent from my SM-G928V using Tapatalk
  6. #6 Re: Change Vin / Serial Number of Bin File
    this is the only thread with this info in it that i know of, its inside a dhp bin drop box thread. cause it goes hand and hand with bns
  7. #7 Re: Change Vin / Serial Number of Bin File
    Mar 2016
    Monroe louisiana
    oh i really meant changing vin in hptuners
  8. #8 Re: Change Vin / Serial Number of Bin File
    you would need to have that other vin unlocked to do that. aka pay up more credits. for just that car, or the whole year if the same year.
  1. hp tuner serial/usb input software
    By SgtMarshal in forum PCM Tuning
    Last Post: 06-10-2015, 06:19 AM
  2. fob serial #....how to turn off the alarm without fob?
    By 97grandprix1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2014, 09:40 PM
  3. Replies: 7
    Last Post: 05-06-2013, 10:13 PM
  4. Adding VIN and Serial to Bin?
    By Pure2sin in forum PCM Tuning
    Last Post: 01-18-2012, 02:01 PM
  5. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
