Thread: Easy bench harness 99+ and 04+
Results 1 to 6 of 6
  1. #1 Easy bench harness 99+ and 04+
    SE Level Member 04whitegtp's Avatar
    May 2014
    Lansing Michigan
    My junkyard build bench harness.
    Blue Pcm connector from an ecotec grand am
    Blue pcm connector from 3800/ls car.
    Obd2 port.
    Using this guide it was just sodering and connecting the correct wires.
    https://www.google.com/url?sa=t&sour...0iEA9smvLYfvhw
    Sent from my SM-N920P using Tapatalk
    Using Tapatalk
  2. #2 Re: Easy bench harness 99+ and 04+
    thanks, i just re wired my 04 up off board, now i need a 04 up pcm to test it on lol
  3. #3 Re: Easy bench harness 99+ and 04+
    Oct 2011
    Toledo, OH
    Wanna post a write up of exactly what pins to what pins for the 04+ ?
    7"
  4. #4 Re: Easy bench harness 99+ and 04+
    E40 (Gen-IV V8) and LLY Diesel Controllers copy this one.
    controller to the obd2
  5. #5 Re: Easy bench harness 99+ and 04+
    May 2014
    Lansing Michigan
    Exactly what i did. I wired mine for can (+/-) and class 2. That way it should do any controller with the 04+connection.
    Using Tapatalk
  6. #6 Re: Easy bench harness 99+ and 04+
    Oct 2011
    Toledo, OH
    Here's mine. With red switch for power and green switch for "ignition". Worked perfect, powered off a hacked PS3 power supply and successfully wrote my first BIN offline with DHP.
    Easy bench harness 99+ and 04+ Attached Images
    7"
  1. dyno or bench tune?
    By SleeperGS in forum General Tech Discussion
    Last Post: 04-08-2014, 04:29 PM
  2. Bench racing
    By TEK310 in forum Track Sessions and Kills
    Last Post: 02-16-2014, 08:58 AM
  3. Bench Test Driver Information Center (DIC)
    By jejensen in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2011, 08:26 PM
  4. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  5. New work bench
    By Black18Ice in forum Off Topic Discussion
    Last Post: 01-02-2010, 09:24 PM
