After swapping out ur old pcm to a zzp pcm did u notice a difference? I know the specs on the zzp pcm but was the improvement noticeable?
Any specific reason to get a ZZP PCM and not one from Overkill? If your stock I don't see the tune doing a whole lot.
Sent from the Milky Way
If you're close to me I'll flash a tune to your car for $50
Well for now the car is stock but plan on doing some small upgrade for it, and dsmuts where r u from
coldwater oh
Coldwater ohio?
Being stock I can tell you a tune will still be beneficial because you'll have better shift points, extend tranny life, increased power, better acceleration and use less fuel at WOT, and waaaay better fuel economy overall. what I love most about Overkill's tune is it pays for itself. All the gas I've saved so far has already paid off the PCM.
I don't trust ZZP enough to buy their PCM
I had a brain fart and forgot about all that stuff, better shoot me now
Yeah hes in coldwater ohio
U have a scanner to tuned it?
Yeah I have dhp tuner and hp tuners
U will charge me 50.00 for u to install a programmer in my computer?
Yes $50 for a tune
Reasonable ur bout 4 hrs away, but doesn't each tune can only old 1 car
Zzp tuning is top notch.
I personally wouldnt tune a car that didnt NEED it but there are nice driveability things that zzp does to the trans. You shouldnt really look for more power out of one.
Well I'll be dipped in pigchit and rolled in pepper, That has to be a first.
Now I feel better about my ZZP PCM that I have been using since 08.
The shift points are more noticeable than stock.
I have had no problems with it and when I installed it all I had to do was start the car and drive.....no learn
