Thread: rear end swap
Results 1 to 20 of 38
  1. #1 rear end swap
    Because Firebird Govna47's Avatar
    May 2011
    Oak Ridge
    A guy I know is selling a built rear out of his wrecked WS6. Was thinking about putting it in my V6 auto. What problems would I most likely run into when trying to do the swap?
    2001 Pontiac Firebird 3.8L V6 - now accepting donations for new rear end - woot
    Why There's a Firebird Invading your Zone
    2001 Ferd Exploder Sport 4.0
  2. #2 Re: rear end swap
    Apr 2013
    Suffolk, VA
    none for the most part. If it was out of a WS6 it had the 3.42 rear end ratio. Check to make sure if the rear out of the WS6 was a 4 channel rear end (TCS +ABS) or a 3 channel (just ABS). I swapped a WS6 rear end in to my 02 Camaro V6 with the Y87 package and it dropped right in. Plus you'll get the bonus of the larger WS6 sway bar
    The biggest thing is to check which kind of rear end your car has now (3 or 4 channel) and make sure it matches the rear thats from the WS6. If not, then its a bit of a hassle to keep the ABS/TCS.
  3. #3 Re: rear end swap
    May 2011
    Oak Ridge
    Quote Originally Posted by philbar71 View Post
    If you didn't live in VA, I would give you the BIGGEST hug ever. this is the information that I've been looking for and all I ever got was "shoulda got a V8" (see:http://www.grandprixforums.net/why-d...why-76600.html)
  4. #4 Re: rear end swap
    Shoulda had a V8.
  5. #5 Re: rear end swap
    May 2011
    Oak Ridge
    does GPF have a facepalm smily? lol
  6. #6 Re: rear end swap
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Quote Originally Posted by Govna47 View Post
    Smiley*
  7. #7 Re: rear end swap
    Ontario
    This thread now delivers.
    "Should've had a V8"
  8. #8 Re: rear end swap
    May 2011
    Oak Ridge
    oh you guys...
  9. #9 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Yeap no problem! Any other questions and I can more than likely answer them. I just joined a day or so ago because I MIGHT be trading the camaro (with a bad trans) for a GTP...
  10. #10 Re: rear end swap
    May 2011
    Oak Ridge
    gotcha. I would miss this thing dearly if I got rid of it.
  11. #11 Re: rear end swap
    Apr 2013
    Suffolk, VA
    I sure am gonna miss it. Mine was Sunset Metallic with Ttops. Looked amazing in the direct sunlight.
  12. #12 Re: rear end swap
    May 2011
    Oak Ridge
    sounds purty. any pictures?
  13. #13 Re: rear end swap
    Apr 2013
    Suffolk, VA
    This is what It looked like when I got it,
    This is what it looks like now
  14. #14 Re: rear end swap
    May 2011
    Oak Ridge
    that is a gorgeous color
  15. #15 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Yep. Too bad the trans had to die
  16. #16 Re: rear end swap
    May 2011
    Oak Ridge
    shame
  17. #17 Re: rear end swap
    I live here. TLSheff's Avatar
    So which part is off on the car... the headlights or the tails? Because the first doesn't match the other.
  18. #18 Re: rear end swap
    For the record, while yes, it could be a 3.42 gear ratio, that is not all that was optioned.
    You're options for Firebirds (bear with me) rear end gear ratio's are as follows.
    5-spd - 3.23:1 (ignore this, 5spd was only base v6 option
    6-spd - 3.42:1
    4-spd - 2.73:1 (standard equp)
    4-spd - 3.08:1 (option)
    So depending on the which transmission it had and what ratio it was equipped with will depend on which ratio you need to adjust for. Biggest thing is with an auto it will throw off shift points and speedometer readings. It will need to be tuned for the proper rear ratio but that isn't hard to do.
    The WS6 option package was mearly suspension equipment, springs/shocks, sways, rims/tires, exhaust tips, shifter, and a few other mostly appearance options. Engine/trans mods never changed, those were based on if the car was going to be a base model, Formula, or T/A.
  19. #19 Re: rear end swap
    Apr 2013
    Suffolk, VA
    Tails are off a LT1. Its a 2002...
    6-spd - 3.42:1
    Since the rear is off of a WS6 its more than likely got the 6Speed and 3.42s. How many auto WS6s do you see?
  20. #20 Re: rear end swap
    Ummm... 3 personal friends of mine have autos, and the 1 we are selling at the GM dealership I work at is an auto. I have seen more auto WS6 cars than 6-spds so.... yea.
    I can start pulling production numbers if you want.
    Actually... just in 02 its about half and half. Click here
    WS6 RAM AIR COUPES 12,212 UNITS (16.9% OF PRODUCTION)
    6,828 units had MN6 6-speed manual transmission
    5,384 units had MX0 Automatic transmission
    WS6 RAM AIR CONVERTIBLES 2,696 UNITS (3.7% OF PRODUCTION)
    1,176 units had MN6 6-speed manual transmission
    1,520 units had MX0 Automatic transmission
    Trust, its based on options. WS6 has nothing to do with motor/trans codes.
  1. Replies: 20
    Last Post: 03-26-2013, 11:05 AM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. Help rear head gasket swap
    By shihiran in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 04:04 PM
  4. 98 grand prix rear head cylinder swap
    Last Post: 05-27-2010, 12:10 PM
