Thread: Which gauges to get?
Results 1 to 9 of 9
  1. #1 Which gauges to get?
    Feb 2015
    california
    Ihave a 2002 gtp and am wanting some recommendations as to which 3 gauges or top 5 i should consider on getting.
  2. #2 Re: Which gauges to get?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    AeroForce then whatever. Either trans temp, boost, oil pressure (electrical not mechanical) or whatever.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #3 Re: Which gauges to get?
    Howell, NJ
    This belongs in general discussion, not the classifieds.
  4. #4 Re: Which gauges to get?
    Kemmerer, Wyoming
    aeroforce and a wideband
  5. #5 Re: Which gauges to get?
    I break stuff selliott's Avatar
    Kansas City
    1 Aeroforce interceptor, which will give you trans temp, oil pressure, knock etc.
    2 Wideband
    3 i have a boost controller in my 3rd slot, but im turbo.
  6. #6 Re: Which gauges to get?
    SE Level Member Boilermaker894's Avatar
    Jan 2014
    Indiana
    Aeroforce wideband oil pressure Trans temp. And oil temp
    01 gtp special edition "special ed" k&n cai slp headers slp exhaust gen v ssic
  7. #7 Re: Which gauges to get?
    Feb 2015
    california
    E hat is the benefit of wideband and trans temp?
  8. #8 Re: Which gauges to get?
    Feb 2013
    Missouri
    Wideband is a very accurate way to track if you are running lean or rich. Transmission temp provides the temperature of your transmission fluid, which is a good indicator on how your transmission is holding up. If you don't have a transmission cooler, you probably need one.
  9. #9 Re: Which gauges to get?
    Feb 2015
    california
    would this gauge work on a 2002 gtp? http://www.aeroforcetech.com/project_5.html
  1. Gauges
    By Metalbluegp in forum Visual/Body Modifications
    Last Post: 06-05-2013, 10:31 PM
  2. Gauges
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 02-28-2013, 11:45 AM
  3. Gauges Im Doing!!!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 05-05-2010, 12:08 AM
  4. gauges
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-29-2009, 02:24 PM
