Hi all, my old '95 Grand Prix SE has a new quirk. When I first start up, no problem, but after a bit a very noticeable squeak comes from deep down in the steering column when I turn the wheel, even if it's only a small turn. Even at a full stop, slight pressure either way on the wheel gets the squeak. It's definitely not the normal low-fluid or failing-pump whine. The car has a fairly new steering pump, fluid level is good.
It sounds like something's dry. I see under the dash where the mechanism goes into a covered tunnel of some sort, presumably down to the rack, that seems like about where I hear the noise from. I suspect I have a leak in the rack & at this point simply finding where to refill it seems like a good next short term step.
Anyone have thoughts or ideas about what the issue is? Where do I add rack fluid? Is there some other potential source, like a grease nipple under the dash or car, for the mechanism leading into the rack?
Thanks for all ideas & comments.
