Hello everyone
I am trying to figure out whats causing an odd issue with my car, its the N/A V6. It seems that when in 4th gear and applying steady on the gas pedal if between 1000-2000 RPM's the car begins to jerk and or feel like its shuddering, miss firing. Its fine in the other gears and when accelerating around the same range. It has power and idles fine, no check engine light on. If I have the car in park tho and try to steady the RPM's between the 1000-2000 range, it will start to flutter and then drop then hold then drop all slowly. Prior to this happening I replaced the battery. Also changed prior to this happening was the ICM, all 3 coil packs, plugs, wires, and air filter. I just cleaned the MAF sensor and tried to clean the throttle body but couldn't really because the car was still to hot. I tried disconnecting the battery and resetting the car and that didn't work either. I know the 06-08 Grand Prix's are drive by wire and I am starting to think its either the TPS and or the gas pedal itself that is acting up. The car seems to do it all the time for this week so far but not constantly, its sporadic. I thought I would ask and see what anyone else may think. Sine the car hasn't thrown a check engine light, im at a loss.
Thanks for the help.
