Thread: 3800 rear main seal cover plate gasket orientation
Results 1 to 20 of 20
  1. #1 3800 rear main seal cover plate gasket orientation
    SE Level Member Lou and Blue's Avatar
    Oct 2015
    Baldwin, NY
    This is my first post in this forum. I am being told that I must have installed my rear cover plate gasket on backwards because I removed and reinstalled the rear cover plate to change the main seal, and I am only getting oil to the lifter bank on the alternator side . The lifters (and hence rockers) on the ac compressor side are dry.
    Can anyone post pics if how the gasket should be installed?
    1996 series 2 from a bonneville
    Thank you guys !
    Louis
  2. #2 Re: 3800 rear main seal cover plate gasket orientation
    dont think the back cover gasket can stop oil from getting to 1/2 the engine.
    are you just cranking the engine waiting for oil to show up out the push rods? do you have a oil pressure gauge hooked up? if are you showing o/p when cranking it?
  3. #3 Re: 3800 rear main seal cover plate gasket orientation
    You can't install the gasket incorrectly, you could use RTV and end up filling the oil passages. Do not use RTV on anything but the bottom 1.5 inches You would have trouble installing the rear cover incorrectly, it sounds like you did though.
    This side faces out
    This side is against the engine, that channel on the right side is for oil. Likely that's the issue.
  4. #4 Re: 3800 rear main seal cover plate gasket orientation
    hangover park IL
    if backwards the BS wont get oil iirc oil galley crossover would be connected.... but excessive use of rtv is a fair culprit in my experience. its why I use permatex aviation sealer
    ~James~ Psychotic Gearhead
  5. #5 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    I have the cover on correctly but ever since I did the rear main seal there has been lifter noise. I didnt hear the motor run before I did the gaskets. When the engine is running and driving its rattling from the rockers on the ac side of the engine. So I removed both valve covers and the alternator side is getting oil and squirting oil from the pushrods but the ac side is completely dry. I have tried motor flush, valve medic, marvel
    mystery oil and rislone (which mysteriously silenced the tapping noise temporarily) and then I did an acetone flush (2q40w oil ,2 q ATF, and 1q acetone. And it didnt stop the tapping sound. Here's a link to what's been happening.
    http://www.fiero.nl/forum/Forum2/HTML/136554.html
    I didn't use any rtv on the cover , just the gasket from zzperformance. I am planning on pulling the engine out and separating it from the tranny to replace the rear cover gasket, I am hoping it is on backwards so this oiling issue can be solved.
  6. #6 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Oh and both electric dash ooil pressure gauge and mechanical gauge both read 60 psi at idle and higher when revved.
  7. #7 Re: 3800 rear main seal cover plate gasket orientation
    dont make more threads, bump this one please. i deleted the other one.
  8. #8 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Here the whole story
    Ok , sorry but I've been asking around so much . Here's the rundown:
    1996 bonneville 3800sc (series 2) - bought the engine with 100k miles on it and I replaced the lim gasket with the zzp aluminum gasket and also did water pump, replaced rear main seal and cover plate gasket, put a 99 Grand Prix oil filter adapter on with the spring and check valve correctly. Also replaced lifters which were primed (soaked over night in oil and pumped before install) And also installed new pushrods. When running the engine I get 60 psi at idle so the oil pump is ok but only the pushrods on the alternator side of the engine are getting oil squirting up and the pushrods on the ac compressor side of the engine are completely dry. I tried motor flush and then rislone and the second drive with rislone the horrible tapping sound silenced and then came right back on the next drive. Thinking I had a clogged oil passage I tried valve medic and marvel Mystery oil but the rattlly tapping is still loud and noisy (no oil to that ac comp side valve train) . So I did a 5-7 mile drive with 2quarts 40weight oil, 2 quarts ATF, and 1 quart acetone. The rattle is still as loud as ever meaning no oil to that side. First I was told I prob have the rear main seal cover plate gasket on backwards preventing oil to that lifter bay.but then I read and see by the gaskets appearance that if that happened it would only be the balance shaft that would be starved oil . Now I am getting info about a dual check valve oil filter adapter that was needed and that that could be starving the ac compr side Lifters oil. I'd rather not have to pull the engine out and take it off the tranny just to find out that the gasket for the rear main seal cover was ok to begin with. Is there such an oil filter adapter with dual check valves? Please help!!! (Oh and thanks for reading this whole thing)
    Louis
  9. #9 Re: 3800 rear main seal cover plate gasket orientation
    James.. aka 400 is the guy that would know.
  10. #10 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    How can I contact him? What's his username , ill pm him.
    Thanks!
  11. #11 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Also, I tried to post this on the 3800pro forum but it wouldn't let me register. If anyone is a member there please post this and anyone who has ideas can email me mrlduet @ yahoo . Com
    Thanks guys
  12. #12 Re: 3800 rear main seal cover plate gasket orientation
    hes talking this guy here. Turbocharged400sbc seems hes taken the time to cut up a lot of heads, blocks and such.
  13. #13 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    I PMd him, thanks.
  14. #14 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Bump . Somebody's gotta know something related to what's going on....
  15. #15 Re: 3800 rear main seal cover plate gasket orientation
    hangover park IL
    the only path for oil to get to the front bank from the rear bank oil galley is through that rear block cover.
    either you shoved a piece of old gasket into the passage or something else happened.
    your yanking the engine any way you look at it
  16. #16 Re: 3800 rear main seal cover plate gasket orientation
    and if you want to see even more.. Look up ^^^ on 3800pro by searching on oiling deficencies. It's a slow starting thread...til the plasma cutter comes out
  17. #17 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Quote Originally Posted by Turbocharged400sbc View Post
    so the ONLY way that the ac compressor side lifters get oil is through the rear cover plate? There's no front oil feed for that side lifters In The timing chain area?
    Id rather not have to remove the harmonic balancer and timin chain cover if its not goin to reveal anything or if there's nothing to fix there. It would be less of a job to pull the engine, pull off the tranny and inspect that rear cover plate only.
  18. #18 Re: 3800 rear main seal cover plate gasket orientation
    hangover park IL
    Yup.
    Early SII from 95-97.5ish have a rear cover with a shallower crossover groove that caused valve train noise on the early engines so pretty much all 98 and later rear covers have a much deeper crossover path between the two divots which line up with the primary oil galley in the rear bank and the secondary galley which is only for the lifters on the front bank.
    that is the only passage it is not like the earlier engines which have drilled crossover path and an integral rear bulkhead that is quite a bit sturdier than the series 2 even if it is heavier
  19. #19 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Excellent info ! Thank you so much . It HAS to be that coverplate being obstructed. Weird thing is that it silenced with rislone for one drive , anyway I got the rear cover plate gasket in today and the bolts should be in by the end of the week.
    If you know where I could buy a 99 or up rear cover plate would that fit my 96 engine? If it would provide more oil passage than it would be helpful. But I bet mine is clogged or it is the gasket being in backwards that's the issue. At least I know I don't have to disassemble the front end timing area and the supercharger and lim and all.
    If a newer year cover plate will work and you know where I can source one PLEASE let me know.
    Thank you!
  20. #20 Re: 3800 rear main seal cover plate gasket orientation
    Oct 2015
    Baldwin, NY
    Oh and could the rear cover plate gasket being installed backwards cause an Obstruction to that lifter side?
  1. bushings in rear main seal cover
    By BLUESMOKEGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2015, 01:32 PM
  2. Rear Main Seal Opinion
    By 50Coupe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:24 PM
  3. Do i need to remove crankshaft to replace rear main seal
    By GTPlzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2013, 11:00 AM
  4. Rear main seal
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2012, 02:03 PM
  5. Rear Main Seal Plate
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2011, 05:49 PM
