One problem after another. Just fixed the cooling system, now I'm having more issues and I'm pretty sure it's the CV axle and/or wheel bearing. When hitting even small bumps there is a loud clunking or popping sound and when I'm in reverse with the brakes almost fully applied I can feel and hear a grinding type of sound(new as of this week). It's hard to hear sounds at speed because of my intake and exhaust so I can't tell if there is a sound when turning or not. The CV axle appears to have a torn boot and throwing grease but I haven't worked much with them before except when I replaced them because they were causing severe vibration so not sure about signs. This was less than a year ago, could it really already be bad again? The passenger side seems to have greased up the ABS cable, but it doesn't appear to be throwing grease like the driver side. I don't know if it could have damaged it, but I had a tire that kept deflating over night for a while and I'd have to air it up in the morning. Could that have caused premature failure in the CV axle or wheel bearing assembly? Appreciate any help guys. Haven't had more than 3 days since I bought this car that it worked like it was supposed to, would like to get this fixed ASAP.
