I was wondering if anyone runs a stock pump with 42.5 injectors? I've heard some people do but they use a rewire kit what exactly is the rewire kit and where do you get one?
A rewire kit is nothing more than larger wire and a relay and fuse to run for your fuel pump. Use the old wire from the pump to turn on a relay that is wired with 12-10 gauge wire.
Jeff
I'm running 42# injectors on a non return system with a stock pump on my 04 comp g
Nope. I just bought a racetronix on yesterday because I switched to Aussie style fuel rails and the #5 cylinder is the last to get fuel and now I have a mysterious #5 misfire at idle only. I'm thinking since I don't have a return, the #5 cylinder is starving of fuel. I ran 42s on my stock fuel rail setup for two months with completely no issue
I'm all this is pointless if you still have the small gauge wire on the pump side of the connector
