Thread: Wheel bearing torque? Axle torque?
Results 1 to 20 of 22
  1. #1 Wheel bearing torque? Axle torque?
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I need to replace my front driver-side wheel bearing hub. I have noticed on rock auto that diff hubs have diff torque specification some don't state a torque specification at all. Any suggestions? I have read of diff things as far torque.
    Also do I need new hub bearing bolts and torque them as well? I was thinking to get dorman for about $65, but they have a few for 35 bucks etc...
  2. #2 Re: Wheel bearing torque? Axle torque?
    The bolts that bolt into the hub itself do not need to be replaced. The spec is german, so "good n tight".
    The axle nut is 118 ft lbs.
  3. #3 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    Got cha... That's what I saw on most of the w body hubs, just weird they recommend so many different axle nut torque spec values.. Thanks
  4. #4 Re: Wheel bearing torque? Axle torque?
    Antioch, IL
    156 ftw!
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    A few did say 159 maybe I'll go with about 135ish lol. Honestly I know a few people who have went through quite a few hubs for this very reason.
    DURA INTERNATIONAL 29513121
    Front; w/ Steel Sensor Wire Clip (Axle Nut Torque 118 ft. lbs)
    WJB WA513179 {#513179} 118 foot lbs torque spec
    Front; Standard Hub Unit; 2nd Design; Plastic Sensor Wire Clip
    DURA INTERNATIONAL 29513179
    Front; w/ Plastic Sensor Wire Clip (Axle Nut Torque 159 ft. lbs)......smh
  6. #6 Re: Wheel bearing torque? Axle torque?
    Antioch, IL
    I did the higher number, almost 30k on them
  7. #7 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    What brand did you go with?
  8. #8 Re: Wheel bearing torque? Axle torque?
    Antioch, IL
    cheapest ones advance had at the time
  9. #9 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    Yeah they got a few for 35 bucks on rockauto ...looks tempting.
  10. #10 Re: Wheel bearing torque? Axle torque?
    Quote Originally Posted by chicagochuck View Post
    Idk if I would trust those.
  11. #11 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    yeah prob go with the dorman at 65 not most expensive but not the cheapest. Plus iv used the brand before....
  12. #12 Re: Wheel bearing torque? Axle torque?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    The cheap ones last two years or less depending on how much driving you do.
  13. #13 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    Got cha
  14. #14 Re: Wheel bearing torque? Axle torque?
    Personally.. I moog'd it at my local parts store for the 3 year warranty. You have a W body.. it'll eat hubs. Might as well have the old one in the box ready to be refreshed for free.
    Also.. never buy without a discount code if at Advance (Retailmenot.com)
  15. #15 Re: Wheel bearing torque? Axle torque?
    hangover park IL
    148-156 new
    I do 130-135 used.
    I get used junkyard bearings alot. Love em...
    ~James~ Psychotic Gearhead
  16. #16 Re: Wheel bearing torque? Axle torque?
    Jul 2010
    Coquitlam,BC,Canada
    I've done two SKF torqued to 159, and 2 SKF torqued to 118. All 4 bearings failed within 2 years. I am now a few months into a Delco torqued to 118; I should be replacing it in a year or so.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Wheel bearing torque? Axle torque?
    Aug 2012
    Chicago
    Yeah I see these cars do eat the bearings no matter what. I found a dorman hub, on rock auto that's suppose to be limited lifetime warranty.. the only one I could find that was warrantied that way. Just letting you guys know....
  18. #18 Re: Wheel bearing torque? Axle torque?
    Jan 2009
    Tallahassee, FL
    I always just made them as tight as I could with a breaker bar, I've had the same luck as everyone on here, new ones every few years.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  19. #19 Re: Wheel bearing torque? Axle torque?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    I have torqued the axle nut on new Moog front bearings to 148lbs and they only lasted 20,000 miles. Now, I try and find any used ones from scrap GP's and just make sure I tighten the axle nut to around 148lbs. I don't believe the torque spec means anything.
  20. #20 Re: Wheel bearing torque? Axle torque?
    Jan 2009
    Tallahassee, FL
    The correct torque probably makes them last 20,000 miles instead of 19,999 miles.
    77 Morris Garage B
  1. Torque rating for wheel bearings ? Axle nut size ?
    By GTP in RTP in forum Brakes/Suspension/Chassis
    Last Post: 02-12-2016, 04:45 PM
  2. Need torque ratings for 1999 front bearing assembly
    By jammy in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2014, 03:44 PM
  3. Torque Spec for wheel bearing and Axle Nuts
    By bjornbjorn in forum General Tech Discussion
    Last Post: 08-11-2014, 12:11 PM
  4. axle nut torque specs question
    By kyle91 in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 02:47 PM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
