Thread: Vacuum leak? 06 GXP
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Vacuum leak? 06 GXP
    GXP Level Member
    Mar 2015
    Tomball
    Well, I must have Elmer Fudd Syndrome, I've R&Red it many times and never had to relearn anything, but maybe that's why my car doesn't go into boost what's the procedure?
  2. #22 Re: Vacuum leak? 06 GXP
    Apr 2015
    Houston
    91parkave; did you go through the same thing?
  3. #23 Re: Vacuum leak? 06 GXP
    Quote Originally Posted by J57ltr View Post
    Not so much an issue with the 3800, though I guess it could never hurt to see if a learn is able to be done.
    But basically any Gen 4 V8 from GM, so 07+ motor but included in the LS4 that came out in 2005 are known for throttle body issue have cleaning them. I've cleaned many and not had and issue but I never touched the throttle blade.
  4. #24 Re: Vacuum leak? 06 GXP
    Apr 2015
    Houston
    I did touch the throttle blade. It had carbon build up on the edge.
  5. #25 Re: Vacuum leak? 06 GXP
    GXP Level Member
    Mar 2015
    Tomball
    When I first got my car I pulled the TB off to clean it, opened the butterfly by hand and cleaned the crap out of it. Didn't have any issues after reinstalling it so I don't think that's the issue. There Re several threads that say it's no big deal and that the FSM has no mention of the 3.8 or 5.3 for a relearn. FFDP was the author of a couple.
  6. #26 Re: Vacuum leak? 06 GXP
    Arizona
  7. #27 Re: Vacuum leak? 06 GXP
    Apr 2015
    Houston
    It says do not perform this procedure if DTCs are set. Should I clear DTCs first and then do it or is that not how it works?
  8. #28 Re: Vacuum leak? 06 GXP
    Arizona
    What dtc do you have
  9. #29 Re: Vacuum leak? 06 GXP
    Apr 2015
    Houston
    At first p0420 and p0121. Then I cleared codes but p0420 came back.
  10. #30 Re: Vacuum leak? 06 GXP
    Arizona
    Just perform the procedure
  11. #31 Re: Vacuum leak? 06 GXP
    GXP Level Member
    Mar 2015
    Tomball
    Did you preform the procedure and how did it go?
    Jeff
  12. #32 Re: Vacuum leak? 06 GXP
    Apr 2015
    Houston
    No. I got a different app called car gauge pro with which you're suppose to be able to perform an idle relearn but I haven't figured out how yet.
    It looks like my idle is slowly getting closer to where it's suppose to be. But when I'm driving and let go off the gas to coast to a red light, the rpm's still go down very slowly.
    According to torque pro my vacuum at idle with car in neutral is a steady 18inHg. When I put it in drive it goes down to 14-15.
  1. vacuum leak?
    By hollas13 in forum General Tech Discussion
    Last Post: 12-11-2014, 10:49 PM
  2. Odd vacuum leak?
    By Dallasneon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2012, 01:21 AM
  3. Vacuum Leak?
    By crock in forum General Tech Discussion
    Last Post: 08-21-2011, 12:09 AM
  4. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  5. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
