Thread: Car leaking, not sure from where.
Results 1 to 3 of 3
  1. #1 Car leaking, not sure from where.
    USA
    I woke up this morning to fluid on my garage floor. The fluid appears to be minimal but a first. Some of it was fresher then others, and the freshest was a brownish color located mostly near the front right wheel. All pictures taken were from the front right and in the pictures I believe the leak is coming from behind the pulley, any ideas where or what it could be? 04 GP NA
    Car leaking, not sure from where. Attached Images
    Stattama T67 Turbo, A2A IC, SLP Cat Back Exhaust, Oversized ZZP radiator, ZZP 1" Transmisson chain, PRJ Ignition Wires, MSD Ignition Coils, Inferno Ram Air Hood, Powerslot Brake Rotors and Pads, 18" American Racing Muscel Phanton, HP Tuner
  2. #2 Re: Car leaking, not sure from where.
    There are 3 things it could be.
    The front main seal, the oil pan gasket or the oil pressure switch on the back of the oil filter housing.
    I would clean everything the best you can and run the car for a little while, then figure out where the leak is coming from.
    Use purple power, simple green or a soap dealio and a pressure washer to get everything super clean. Do it in the street for something to avoid stains on the driveway,
  3. #3 Re: Car leaking, not sure from where.
    GXP Level Member
    Mar 2015
    Tomball
    The oil sender is notorious on other 3.8's they usually leak right out of the connector.
    Jeff
  1. Leaking
    By gtpzmdc in forum General Tech Discussion
    Last Post: 08-17-2012, 01:59 PM
  2. Replies: 21
    Last Post: 03-07-2012, 02:10 PM
  3. 08 gp leaking oil??
    By 08 gp lvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2011, 07:20 PM
  4. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  5. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
