Thread: transmission cooler line to radiator size
Results 1 to 5 of 5
  1. #1 transmission cooler line to radiator size
    Jan 2015
    Overland Park, KS
    Hi guys I have a 2004 gtp that I'm replacing the radiator on. I ordered a spectra radiator off rock auto that is supposed to fit, part #cu2862, however the fittings for where the trans cooler lines go in are too small. The trans cooler lines themselves are larger than the openings on the radiator so it looks like I will have to order a different one. I ordered the spectra because it has a 1" core vs the 5/8" the stock size. My question is are there different trans cooler line sizes? Since mine doesn't have the ws6 package would I run into the same problem if I ordered the acdelco one with the ws6 package since it has a thicker core?
  2. #2 Re: transmission cooler line to radiator size
    Arizona
    Why don't you skip that **** and use a aftermarket cooler
  3. #3 Re: transmission cooler line to radiator size
    Jan 2015
    Overland Park, KS
    Thank you for the suggestion but I wasn't looking to run an external cooler.
  4. #4 Re: transmission cooler line to radiator size
    Dec 2012
    Where 4T65E's were born
    Can't you swap fittings on the radiator?
    Sold.
  5. #5 Re: transmission cooler line to radiator size
    Jan 2015
    Overland Park, KS
    I hadn't thought about that, I will try swapping the fittings this afternoon
  1. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  2. radiator side transmission oil cooler connector part #?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2014, 07:30 PM
  3. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  4. Transmission cooler line
    By jhnnyboz in forum General Grand Prix Discussion
    Last Post: 08-24-2012, 08:03 AM
  5. Transmission Cooler Line leaking at radiator
    By Obrigado in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 04:36 PM
