Thread: What is it with the coolant system in these cars
Results 1 to 18 of 18
  1. #1 What is it with the coolant system in these cars
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    My 97 and 05 do the same thing it runs cool till I com up my hill or hard throttle
  2. #2 Re: What is it with the coolant system in these cars
    That doesnt help me any.
    Have you done ANYTHING to figure it out??
    Coolant flush, new water pump, new thermostat???
    A sticking thermostat will make the heat up time take longer.
  3. #3 Re: What is it with the coolant system in these cars
    flush both heater cores. both are air bound.
  4. #4 Re: What is it with the coolant system in these cars
    Nov 2012
    I put everything in my 97 new including radiator but I haven't really done anything to my 05 but put it on the genesis at wor and it says is some type of malfunction
  5. #5 Re: What is it with the coolant system in these cars
    your not helping us help you. codes go a long way.
  6. #6 Re: What is it with the coolant system in these cars
    Nov 2012
    My 05 is doing the same thing as my 97 and I done everything short of a flush it the intakes are seeping in my 05 I don't want to take a chance and blow the gaskets out
  7. #7 Re: What is it with the coolant system in these cars
    Enfield, CT
    Could you elaborate a little bit more about your issue? How long is the car running before it hits operating temp? The LIM gaskets need to be replaced asap. Also using periods and commas will help you out as well. Grammar goes a long way.
  8. #8 Re: What is it with the coolant system in these cars
  9. #9 Re: What is it with the coolant system in these cars
    Nov 2012
    It runs at the 1/4 mark on the temp gauge and when I come up my hill the temp rises quick or under hard throttle
  10. #10 Re: What is it with the coolant system in these cars
    Antioch, IL
    potato by smetters20, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: What is it with the coolant system in these cars
    Donating Users timboku's Avatar
    Montgomery, IL
    Collapsing radiator hoses
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  12. #12 Re: What is it with the coolant system in these cars
    hangover park IL
    with the hills out there it could just be that your working the engine/trans hard and or you may be experiencing trans slippage which the trans cooler pumps the heat into the coolant via the radiator mounted H/E
    ~James~ Psychotic Gearhead
  13. #13 Re: What is it with the coolant system in these cars
    SWPA
    Quote Originally Posted by Lil larry View Post
    THe "1/4" mark on the later ones, at least on my 07 is about normal operating temp. When you get closer to the middle mark you are actually getting a little too warm.
  14. #14 Re: What is it with the coolant system in these cars
    Buffalo
    Trans is working hard on the hills . That really heats up the transmission. plus if you use AC , that's another heat load on the cooling system due to the placement of the condensor.
    cleaning the radiator out , dust dirt leaves etc, helps as well as new radiator if dex has coated /plugged the radiator
  15. #15 Re: What is it with the coolant system in these cars
    I'm thinking air in system.
  16. #16 Re: What is it with the coolant system in these cars
    Nov 2012
    I don't feel any slipping in the trans and I was afraid of that being too hot what can I do to eliminate this I don't want to hurt it I might just need to go ahead and do the intakes but I was wanting to do them when I got me a intercooler set up
  17. #17 Re: What is it with the coolant system in these cars
    Mar 2015
    Erie,PA
    Time for radiator hoses, maybe heater hoses, 180 or 195F thermostat and a proper flush and fill with new DEX.
  18. #18 Re: What is it with the coolant system in these cars
    Mar 2015
    Erie,PA
    If your intake gaskets are leaking outside the motor, they are also leaking into the cam valley under the intake manifold. I had them fail completely on my 1997 Lumina with the 3.1L This caused the engine oil to thin out, eventually locking up the motor. 3 gallons of 50/50 Dexcool with turn 4.5 quarts of 5W30 into a useless mess.
  1. Coolant System Flush
    By Alcatraz in forum General Tech Discussion
    Last Post: 05-29-2013, 08:13 PM
  2. Coolant system help needed
    By onetyme77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2012, 07:10 AM
  3. need help with bleeding coolant system
    By loganrick in forum Engine
    Last Post: 12-26-2011, 01:10 PM
  4. how do i bleed air out of coolant system?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-08-2011, 01:21 AM
  5. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
