It suffered a small drop, now it won't light up.
You did check to make sure the plug on the back didn't become loose right?
Right, I even removed it and reseated it.
Sensitive touched one too hard installing it and put line in the display across the screen. Bummer but maybe fixable if you contact areoforce.
Thanks, I've mailed them.
The screen does have a ribbon with a plug into the display board, you could check and see if it came undone. I ended up sending mine in to get a new display board, I believe it cost me around $75 about a year ago.
I looked inside it's looks good. Nothing looks broken or loose.
