Always remember, the limits until breaking into water are not nearly as important as velocity. 9 times out of ten, if you push that far, you're going backwards in power. I get guys with, say XP or S1x cams who want all- out ported heads. The heads I port them won't flow as much as a ZZP or Intense stage 3 or 4 head.
But those heads see max flow at around 600 lift Where an XP or an S1x is only between 520-540.
Porting strictly for velocity can make a pair of heads out-flow the big boys at 550 lift and below where it matters for a smaller cam.
If you don't have a tight enough minimum cross section, you will need more lift and RPM to see the benefits of all your extra work.
Velocity comes first and you never want to sacrifice any of it for volume.
