I Need a regulated 5v source for my Aeroforce air temperature sensor kit, any suggestions? other than buying a 12v to 5v DC regulator?
I thought that was a 12v source no?
Hmm, I guess you're right.
Then I'm not sure were you will get just 5v unless you tapped into a sensor that only is supplied up to 5v.
The EGR is a 5V circuit right? if so is it a steady 5V? or 1-5V?
There are regulated 5+'s off the pcm. You'd need to find the thread with the pcm pinouts and find the right circuit
