Thread: How to fill cylinder with air?
Results 1 to 9 of 9
  1. #1 How to fill cylinder with air?
    Charles City, IA
    What all do I need to make a fitting for my air compressor to fill each cylinder with air so I can replace the valve springs with the heads on?
    SMGPFC Two Nipple General
  2. #2 Re: How to fill cylinder with air?
    Oklahoma
    You dont have to make one, they sell them. I know summit racing has them and Ive seen them in the auto parts stores before.
  3. #3 Re: How to fill cylinder with air?
    Charles City, IA
    JEGS 80522 - JEGS Air Hold Fitting Set - JEGS
    Ok I found these on jegs.com. Took a little searching..
  4. #4 Re: How to fill cylinder with air?
    Oklahoma
    there ya go, you're all set now..
  5. #5 Re: How to fill cylinder with air?
    Moore, Oklahoma
    Be sure the fitting has a long neck on it. I ran into this problem when I was going to replace my valve springs. The ones in the local part stores were too short and wouldn't thread into the heads. I ended up borrowing a compression test kit and it has the right fitting for me. Beware of this, short and stubby won't work. I tried 3 different kinds until I got the right one.
    Wish I had a PN or something to give you. Before tearing down your car, make sure you pop out a plug and make sure it works correctly.
    Good luck....
    Shawn W. Larsen
  6. #6 Re: How to fill cylinder with air?
    Moore, Oklahoma
    BTW, that Jegs kit SHOULD work, the one on the right (the long skinny one) should work well for you. I beleive thats the same style I used for my motor. Just install a air nipple quick connect w/ thread sealer, antiseeze the threads going into the head, and stick in. Leave the compressor on when doing this procedure.
    BTW, if you end up buying that Jegs kit, LMK if the is indeed the correct fitting. I'd love to have one of my own for my tool box...
    Shawn W. Larsen
  7. #7 Re: How to fill cylinder with air?
    Charles City, IA
    Jegs kit will be here tomorrow. I also just got a valve spring compressor from snap on. I will try the fitting right away and tell ya if it works.
  8. #8 Re: How to fill cylinder with air?
    Moore, Oklahoma
    LMK
    Shawn W. Larsen
  9. #9 Re: How to fill cylinder with air?
    Charles City, IA
    The jegs kit did work. The long and skinny one was the one I used.
  1. How much Dex 6 to have on hand to fill dry trans?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2008, 01:34 PM
  2. Master Cylinder Cap
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2008, 10:43 AM
  3. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
