Thread: wheel hub tools...
Results 1 to 13 of 13
  1. #1 wheel hub tools...
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello, i did a quick search and couldnt find exactly what i was looking for. i was wondering if someone could give me a list of tools ill need to replace my wheel hub/abs sensor. im sure i have most of them im just looking for the "special" ones that i might need to get.
  2. #2 Re: wheel hub tools...
    Moore, Oklahoma
    The rear ones you'll need a hub puller tool and slide hammer you can rent at Autozone. The fronts are just bolted on...
    Shawn W. Larsen
  3. #3 Re: wheel hub tools...
    Nov 2008
    Fremont Nebraska
    i took a look at the autozone website, i searched for "wheel hub" and all it came back was ones for the front, by looking at pic of one it looks painfully easy, just 3 bolts and a sensor clip??
    also 2 more questions. both my abs light and trac off light are lit, and neither systems work. does that mean its definetely one of the front ones or could it still be a rear? and also, can anyone comment on ebay wheel hubs??? they're about half the price of autozone ones and i know you get what you pay for, but sometimes good deals do come along....... so i was just wondering if anyone had any experience with those....
  4. #4 Re: wheel hub tools...
    Nov 2008
    Fremont Nebraska
    bump, anyone? any one of those 3 questions?
  5. #5 Re: wheel hub tools...
    TDCRacing
    Guest
    Oreilly's has wheel hubs for 120 a peice. They have a one year warranty. Ebay ones do not and even if they did it would be a hassell to bring them back.
    Correct only 3 bolts for the fronts.
    I'll say this. They aren't easy. But def. do-able.You have to struggle with the suspension to get everything put back together.
    Not that bad though.
  6. #6 Re: wheel hub tools...
    TDCRacing
    Guest
    Guess I still did not answer you're question.
    If it were me I would get them local and make sure they have a warranty.
  7. #7 Re: wheel hub tools...
    Apr 2008
    Bremerton, WA
    ZZP has the fronts for $79.99, and the rears for $89.99. They have a great product line for most things you'll need. I had my right front done last June at a local reputable repair shop for $400, only because I was going out of town on vacation and wanted it done by the time I returned. My left front went out 2 months ago and I did it myself. It is a bit labor intensive, but if you have the desire and the aptitude you can do it. I found out about ZZP carrying them after I did mine. I spent $120 for mine at NAPA. ZZP's are listed under the " products" drop-down menu in the "brakes, suspension, handling" section.
    I can give a step-by-step if you would like, but I'll have to get my manual out to make sure I don't forget something as I write it. Let me know if you need that.
    TMC
  8. #8 Re: wheel hub tools...
    Apr 2008
    Bremerton, WA
    To find out which sensor(s) is bad, take it to a reputable shop and have them test it for you. I have a OBD I & II scanner but it didn't tell me which one was bad. When my left front was going it was the bearing and it was easier to tell by putting the car in the air and running it.
    The tools needed are: 0-250 lb/ft torque wrench, pnuematic impact wrench (if possible) otherwise a 1/2" drivebreaker bar with cheater pipe, 30-something mm socket (i think 36mm), tie-rod seperator, ball-joint seperator, floor jack and jack stands, brass drift punch (to knock out the old hub), three-leg bearing puller (to push the axle out of the spindle), emery cloth (to clean up the bore before installing new hub), wrenches, sockets, needle nose pliers, cotter pin remover is nice to have, I think that's about it.
    TMC
  9. #9 Re: wheel hub tools...
    Nov 2008
    Fremont Nebraska
    holy hell! from the picture i was just expecting to take the tire off, disconnect the sensor, then take off the 3 bolts and pull the part away.
    yes, if you dont mind, whenever you get a chance, i would like to read through a step by step procedure of this
  10. #10 Re: wheel hub tools...
    Apr 2008
    Bremerton, WA
    I have one picture in my profile of the new hub installed and you can see the axle laying to the side on the lower control arm, the tie-rod end to the right, the caliper tied up to the strut spring, etc. I'll ger the step-by-step soon.
    TMC
  11. #11 Re: wheel hub tools...
    Apr 2008
    Bremerton, WA
    Don't stress too bad, you can do this repair. Here's the step-by-step I promised. It is also listed in the "how-to" section now.
    TMC
    Wheel Bearing / Hub Replacement
    Things to buy:
    1. New Bearing/Hub (ZZP has fronts for $79, rears for $89)
    2. New Bearing/Hub bolts 3 ea. (Old bolts have thread stretch from torque. Also the dealer changed the thread pitch recently so check the new bolts to the new bearing/hub prior to start of job.)
    3. Tie-Rod and Ball-Joint separators
    4. Hub Spindle Remover (presses the axle out of the spindle)
    5. New Axle Nut (recommended)
    6. Proper size ½” drive metric nut to fit front axle nut. (33mm?)
    7. Tri-Flow lube (found at Fred Meyers or bike shops)
    8. Scotch-Brite pads (auto parts stores in auto body supplies)
    Bearing/Hub Removal Procedure:
    1. With car on ground, loosen lug nuts then jack up car and place on
    jack-stands, remove tire/wheel. Secure the rotor with two lug nuts.
    2. Use impact wrench or breaker bar to loosen axle nut. To keep axle from turning when using breaker bar, place a screwdriver in-between the gap in the caliper and into the vent slots of the rotor.
    3. Remove brake caliper, caliper bracket, and rotor:
    A) Use a large C-clamp around the backside of the caliper and the
    outboard brake pad and snug up the clamp.
    B) Install a clear hose to the caliper bleeder valve and the other end into
    a jar with a hole in the lid to snuggly retain the hose. Crack open the
    bleeder valve ½ to ¾ turns then tighten the C-clamp until the piston is
    Pushed into caliper bore enough to slide the caliper off. Tighten the
    bleeder valve and remove the hose. No air will enter the caliper using
    this method, therefore no brake bleeding required. I prefer this method
    to letting the fluid back flush to the master cylinder which can cause a
    mess.
    C) Remove caliper bolts and remove the caliper. Tie the caliper up to
    the strut spring out of the way.
    D) Remove the caliper bracket bolts and caliper bracket.
    E) Remove the rotor.
    4. Remove front sway-bar end-link bolt and bushings from sway-bar
    and “Lower Control Arm” (LCA).
    5. Remove the tie-rod nut, then separate the tie-rod from the steering knuckle using either a tie-rod remover or a separator fork and sledge.
    6. Remove the cotter pin from the ball joint castle nut. Loosen the nut 1 to 2 turns. Disconnect the ABS sensor connector, pop the harness retainer from the LCA, and move the harness out of the way. Using a ball-joint removal tool or separator fork, pop the ball-joint stud loose. Remove the ball-joint castle nut. Separate the ball-joint from the LCA. There is a bit of upward force on the LCA so it takes some effort to separate.
    7. Separate the drive axle from the steering knuckle using a Hub/Spindle Remover. The shaft should press out easily. When the splines are separated, remove the tool and grasp the axle and steering knuckle and pull them apart. Lay the axle on the front end of the LCA.
    8. Remove the wheel speed sensor electrical connector from the bracket using a small screwdriver to lift at the underside of the bracket.
    9. Remove the wheel bearing/hub. I had to use a brass drift and a hammer tapping it out from the backside of the steering knuckle due to the corrosion that accumulated in the knuckle bore and the O.D. of the hub.
    Bearing/Hub Replacement Procedure:
    1. Use small wire brush and scotchbrite pads to clean the knuckle bore and all mating surfaces.
    2. Install new wheel bearing/hub using the new bolts. Torque to 96 lb. ft.
    3. Inspect axle shaft boots and splines prior to reinstalling. I use Tri-Flow on the splines of axle and hub prior to reassembly. Install axle to the bearing/hub.
    4. Install the nut and tighten using impact wrench or ratchet. It’s not necessary to final torque yet, just get the axle partially secured.
    5. Install wheel speed sensor electrical connector to the bracket at the bottom of the steering knuckle.
    6, Install the sway-bar end-link bolt up through the LCA and install the lower bushings, washers, spacer and one upper bushing (Bolt will stay in place with the bushings installed). Align the ball-joint stud cotter pin hole front to back. Guide the end-link bolt into the sway-bar while inserting the lower ball-joint stud into the steering knuckle. Another person will be helpful to counter the tension of the LCA while aligning the bolt and stud. Install the ball-joint castle nut.
    7. The torque of the castle nut is 50 lb. ft. but you can’t fit a torque wrench in there, so hand tighten with a wrench sufficiently and align the hole and install the cotter pin.
    8. Install the end-link bolt bushing, washer, and nut then torque to 17 lb. ft. (need deep well socket for this and an “Inch-Pound Torque Wrench”)
    9. Install the tie-rod end to the LCA and torque the nut to 22 lb. ft. plus 115 degrees of rotation.
    10. Connect the ABS connector and install the harness retainer to the LCA.
    11. Reinstall the rotor (hold in place with two wheel lugs).
    12. Reinstall the caliper bracket and torque the bolts to 133 lb. ft.
    13. Reinstall brake pads to caliper bracket. The wear sensor (spring steel tab) shall be at the outboard pad at the top.
    14. Install the caliper over the pads. Clean and lube caliper bolts and boots with silicone brake grease. Torque the caliper bolts to 70 lb. ft.
    15. Torque the axle nut to 159 lb. ft. Use the method with the screwdriver in-between the caliper gap and inserted into the rotor vent to secure axle.
    16. Install tire/wheel and torque wheel lugs to 100 lb. ft.
    CONGRATULATIONS!
    Note: All torque values are taken from the dealer service manuals for an ‘02 GTP. The service manual set of 3 costs $135.
  12. #12 Re: wheel hub tools...
    Nov 2008
    Fremont Nebraska
    damn that is detailed! if you can point me in the direction of a manual like that for an 01 GT, i will gladly pay $135 for that, i bet it even has a couple pics too. i went to autozone for a haynes manual and the one they said was for my car was for about 3 other cars covering about a 10 year range. the manual was not helpful and got returned
  13. #13 Re: wheel hub tools...
    Apr 2008
    Bremerton, WA
    The service manuals can be purchased at helminc.com for $135. They do have the set for the '01 Grand Prix. It covers all models of the Grand Prix for that year only. It should be a 3 volume set as was mine. It is a good investment if you plan to keep your car for a while. The books are a little hard to follow, but when you find the section you need place writeable page markers at the edge of the page so it's easy to find the next time. The detailed list I gave you is a combination of many sections in the manual and my own interpretation. What is frustrating with the manuals is the way they send you from one section to another to complete a repair. I had to search 4 or 5 sections to do that write-up. Still a good tool to have for your car repairs. I also purchas a Haynes as a quick refernce. Hope this is helpful.
    TMC
  1. Scan tools
    By mattio in forum General Tech Discussion
    Last Post: 11-02-2008, 10:07 PM
  2. Daddy got new tools
    Last Post: 06-16-2008, 07:29 AM
  3. Tranny Tools Needed for Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 07:20 PM
  4. BEWARE of Power tools haha
    By 2Fast4U in forum Off Topic Discussion
    Last Post: 02-28-2008, 08:12 PM
