Thread: 2001gt 3800 no power
Results 1 to 4 of 4
  1. #1 2001gt 3800 no power
    Dec 2014
    michigan
    I changed the harmonic balancer, crank sensor, and new battery. Now I don't have any power. Don't have any codes.
  2. #2 Re: 2001gt 3800 no power
    Oct 2011
    Toledo, OH
    Power as in torque/hp? Or electrical?
    Ya gotta do a CASE relearn when you do a crank sensor, timing is probably out of whack.
    7"
  3. #3 Re: 2001gt 3800 no power
    Dec 2014
    michigan
    I'm sorry, by no power I meant that there is no horsepower. It idles fine just does not have any get up and go when you give it the gas.
  4. #4 Re: 2001gt 3800 no power
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    Shot in the dark but try unplugging the maf sensor and then start it up and see how it drives. If it drives better, then take out the maf and clean it with maf cleaner. No codes/ Check engine light right?
  1. How to Flush/Change Power Steering Fluid on the 3800/3.8L Engine
    By 02NavyBlue in forum How To Write-Ups/Tech Tips
    Last Post: 07-28-2017, 11:02 AM
  2. Replies: 3
    Last Post: 11-26-2014, 08:16 AM
  3. 1998 Pontiac grand prix,3800 Series 2 "Power Steering Problems"
    By Gchronic in forum Introductions/Noob Questions
    Last Post: 12-04-2012, 08:02 PM
  4. 3800 Pontiac Grand Prix need more Power
    By Myers1985 in forum Introductions/Noob Questions
    Last Post: 09-04-2012, 04:59 PM
  5. 2004 grand prix 3800 series 3 power-steering pump replacement
    By quickster in forum General Tech Discussion
    Last Post: 03-17-2011, 12:24 AM
