Thread: HID Kits -- dual beam or retractable?
Results 1 to 15 of 15
  1. #1 HID Kits -- dual beam or retractable?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i've found a few different hid kits on ebay, what do you all think?
    -- true dual beam lights, 4 ballasts
    eBay Express: HID conversion kit H4 H13 9004 9007 Bi xenon 4 ballasts - Description
    or another kit, with retracting cover peice, not telescoping bulb..
    eBay Motors: HID CONVERSION BULBS Bi-Xenon H4 9003 9007 H13 Hi/Lo (item 320203889848 end time Jan-11-08 22:55:42 PST)
  2. #2 Re: HID Kits -- dual beam or retractable?
    Oklahoma
    I guess one of these days I'll get around to installing a HID kit. As for me, though, and which one I would get. Well I would prefer to maintain as much OEM functionality as possible and the true dual beam kit seems to do just that.
  3. #3 Re: HID Kits -- dual beam or retractable?
    Saraland Alabama
    I just have heard so many horror stories about guys on ebay selling stuff that doesn't work it makes me nervous
  4. #4 Re: HID Kits -- dual beam or retractable?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    ehh, they prolly dont work because they are cheaper kits, their connetcors are bad, and/or aren't getting the turn on voltage they need. When I get around to it, because I have like 4 other write ups to do, I will post up on how to get more voltage at turn on, and how to avoid them flashing with unlock and lock. so, add one my write-up to my to-do list, haha. Oh well I enjoy it.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  5. #5 Re: HID Kits -- dual beam or retractable?
    I live here. UR LOSN's Avatar
    Rockford, IL
    I have the WBS HID kits...for the main beams, and foglamps on the GTP. THEY ARE BRIGHT!!!!!
    no need for high beams anymore. the only problem I have noticed is that the fuse that comes witht he kits are to small, and just needed uped a bit to handle all the power.
  6. #6 Re: HID Kits -- dual beam or retractable?
    alhambra, Il
    I don't think they make those anymore do they, or they use cheaper kits now? Those are seriously good kits, A member of my local group has them on his car and they are awesome.
    Steven Oliver
  7. #7 Re: HID Kits -- dual beam or retractable?
    GT Level Member BackInBlack's Avatar
    Vermont
    You guys should go read my (un) official HID thread on the "other" site... Twin tube and retracting HID units will NEVER work correctly in our reflector housings. Either lose the high mode and get the static kit, or find a properly designed tilting kit...
    The GPs are long gone...
  8. #8 Re: HID Kits -- dual beam or retractable?
    SW Chicago Suburbs
    Quote Originally Posted by BackInBlack View Post
    seems the properly designed tilting kit doesnt exist!
    but yeah, i read your thread over on the other site, good info there, thanks.
  9. #9 Re: HID Kits -- dual beam or retractable?
    PA
    I would really be interested in a good tilting kit because PA requires high beams. So I don't want to lose them just for that.
    But why won't the dual filament ones work?
    2001 GSE
  10. #10 Re: HID Kits -- dual beam or retractable?
    Vermont
    Quote Originally Posted by Zef_66 View Post
    The dual arc kit won't work because the high beam arc is WAY out of place and NOT adjustable. The 9007 tungsten filaments are very close together and the housings are specifically designed for the 9007 filament placement. Anything out of the correct focal point results in useless light. JCPrix and I have both spent a LOT of time researching the issues. He's going to try a telescopic to tilting conversion on his bulbs.
  11. #11 Re: HID Kits -- dual beam or retractable?
    Saraland Alabama
    have you seen the xenonworx kits? I have access to them, and thought I might try them out (they are owned by METRA)
  12. #12 Re: HID Kits -- dual beam or retractable?
    SW Chicago Suburbs
    are they the tilting 9007 bulbs or retractable?
  13. #13 Re: HID Kits -- dual beam or retractable?
    Saraland Alabama
    not sure, I have them checking the system out on grand prix's for me (sent them some links to the write ups so they could see the issues, and they seem to be responding)
  14. #14 Re: HID Kits -- dual beam or retractable?
    Vermont
    The PROPER tilting kit should tilt the arcs DOWN about .050" and OVER towards the passenger side by about .050" as well. The arc in the LOW position should be centered radially with the base at a distance of 1.75" from the top of the mounting flange.
  15. #15 Re: HID Kits -- dual beam or retractable?
    Saraland Alabama
    I will pass that along to them thanks
  1. Turbo Kits
    By robahr24 in forum Turbo
    Last Post: 01-24-2008, 09:25 AM
