Thread: 95 Grand Prix GTP 3.4 dohc oil pan repair or replacement.
Results 1 to 4 of 4
  1. #1 95 Grand Prix GTP 3.4 dohc oil pan repair or replacement.
    Jun 2010
    long island ny
    Car slipped on the jack as a result got a small hole in the pan. Best way to fix it, I have read that JB weld will work for awhile. How about pan replacement anyone do the job. I would rather not pull the pan. I also have a rack leak to.
  2. #2 Re: 95 Grand Prix GTP 3.4 dohc oil pan repair or replacement.
    Mar 2012
    NC
    The pan replacement isn't too bad if you have a way to lift the engine a little bit. JB weld works too but you use JB weld on a very coarse prepped surface and then I'd do fiberstrand body filler over that with urethane sealant to seal it all up.
  3. #3 Re: 95 Grand Prix GTP 3.4 dohc oil pan repair or replacement.
    Jun 2010
    long island ny
    I have an engine hoist, so I can lift it up. What do you mean by fiberstrand body filler. You mean the bondo with the fiberglass hair in it.
  4. #4 Re: 95 Grand Prix GTP 3.4 dohc oil pan repair or replacement.
    Mar 2012
    NC
    Quote Originally Posted by 67GTO View Post
    Yessir.
  1. 1995 Grand Prix GTP 3.4 DOHC mounts.
    By 67GTO in forum General Tech Discussion
    Last Post: 08-15-2014, 07:18 AM
  2. 91 Pontiac Grand Prix with 3.4 litre DOHC 24 valve
    By dodgemagnum in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-18-2014, 12:02 AM
  3. 95' grand prix gtp (3.4 DOHC) is it normal for.....
    By Falcons33 in forum General Tech Discussion
    Last Post: 04-25-2013, 10:03 PM
  4. 1995 pontiac grand prix gtp 3.4 dohc
    By dawson74 in forum Introductions/Noob Questions
    Last Post: 02-27-2011, 12:58 AM
  5. Grand prix 3.4 Dohc help please
    By Minnesotawhite in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-09-2010, 09:27 PM
