Any one oil undercoat?
Bar and chain oil?
Any one try Fluid Film undercoating?
Bought 2002 ssei w/43,000 miles from NC and want this 12 year old car to last.
Bar and chain oil?
I have never seen it done around here, however it seems as you want to try it Ed??
I know you know about the rust issues. But other than the Front near the wheel wells, and the rear gas door there isn't much on the Body that will rust. I would Paint the suspension components to keep them rust free
Ithurtz used some sort of flaxseed oil stuff under his car. Check out his thread. Turned out great.
My 2003 has been in Chicago it's entire life. I've never done any kind of undercoating, just thoroughly rinse the car top and bottom as best I can during the winter a couple of times. Only rust I have is the typical gas door rust, which only has a couple dimples showing as of now. Grrrrr..
Rest of the under body is completely clean, same goes for subframe, suspension components, mounts, etc etc. Compared to the 92-99 Bonnevilles and the GPs, it seems that the 2000+ isn't as prone to rust.
My 03 Bonneville has 210,000 miles and the rockers and the gas door area have been repaired. Gas door area goes first, rockers rust second, inner front fenders and spring seats are tied for third. Don't think these cars don't rust!!!! They due.
It has seen every snow fall and all the salt in Pennsylvania and Ohio as a daily driver for 11 years now. My daughter drives it now (with a 3.8 pulley) headers, cam, gen 5, intercooler, 3" exhaust and 87 octane.
Lot guys from work swear by oil undercoating and do all there vehicles every year. Motor oil, bar and chain oil, and now fluid film is beckmg popular. Guy from work has 2001 chevy pickup daily driver that has never had any rust work don't to it and it doesn't need anything because the last 7 years he oil under oats it before thanksgiving every year.
Motor oil wears off to fast. Only 1 winter through 1 coat, durable enough for 1 coat. High traffic areas underneath would need more, but I get a little lazy the colder it gets outside.
Turp and BLO go together, nothing else. Used to aid int he drying process, I think I did mine in october it was just a TADDDD tacky at the 4th day. 2nd day it was like you just put it on. Yellow oil paint isnt needed, but oil paint is durable and color is always nice. Get tired of yellow? Get blue, tired of blue, go red! No crazy prep get the crap off and put on another layer of your choice of mixed blo/oil paint/turp.
db7102d2addb3d9fa5203030a428f6e0 by smetters20, on Flickr
1st coat
t9k6 by smetters20, on Flickr
1st coat after a few days
fd5a7706a1af2b28615e2e0c26e25366 by smetters20, on Flickr
1 year later
Untitled by smetters20, on Flickr
You can see the high wear areas after a year and 1 coat. I love it. I did a touch up on a few spots last weekend with a garden sprayer... dam driveway is yellow oops.
Didn't that stuff stain your hands for a few weeks?
Sent from BFE
no that was rust bullet.
Do you drill holes in the rockers so you can spray internal? They have plastic plugs to cap the holes when done.
I've seen all the different recipes, fluid film is expensive but is made to do the job the as is.
eastwood sells their internal frame coater if you wanna spray inside your rockers.
http://www.amazon.com/s/ref=nb_sb_no...x=fluid+%2Caps check the stars/reviews. I'm gonna try this stuff and report back in time
For my Grand Prix's, I have been brushing on POR-15. I apply it to the underbody, paying particular attention to getting it in the rocker panels. I also coat the brake lines and fuel lines, and struts and springs. I have removed the plastic inner fenders and brushed it on the panels. Lastly, I brush it on areas under the hood, like the battery tray.
I don't have an air compressor set up yet, but was told by people who restore their cars it is best to brush the POR-15 on. I have noted I can get the POR-15 coating down into crevasses much better than using any kind of spray apparatus.
It takes a lot of work to get this done, but at least I will never have to worry about large areas of the car rusting out in years to come.
If you wanna sand it down underneath and get it really clean rust bullet or kbs coatings has some 2 step rock hard coatings. Depends how labor intensive you wanna go.
I get it undercoated with parafine/wax oil, green rustcheck stuff. Got holes drilled in panels with plastic caps that goes on them so they can just spray everywhere in the panels and the undercarriage. Get it done once a year. Doesn't drip, doesn't smell bad, help a ton.
