id be changing that icm now for sure.
Before we condemn the cam.. what does the roller of the suspect lifter look like? If it's looking good, then the cam is likely not an issue. No metal in the oil pan is also a good sign that the cam is fine.
Is compression on that cylinder still an issue?
Looks fine.
Joe.. Dave is worried you plan to yank the cam. Looks like it's probably fine and isn't causing your issue.
Thanks bill.
silicone vac lines ftw?
I'll dig around today and let you know if I have one. If not I can pull one for you sometime this week if you don't have access to a JY with plenty of 3800s lol
