Thread: bolt on dbc throttle body for l26 intake manifold
Results 1 to 11 of 11
  1. #1 bolt on dbc throttle body for l26 intake manifold
    missouri
    I've been looking high and low for a drive by cable throttle body for a l26 intake manifold.
    I'm doing a l26 intake swap onto my l36 and id like to avoid using the adapter to use my dbc throttle body. do I have any options other than to use my TB with the adapter and the new to the car l26 intake?
    what about converting the l26 TB to cable operation? pull out dbw motor and weld or replace throttle shaft with cable compatible throttle shaft? or cutting off the l26 intake opening and weld DBC compatible opening in its place?
    what about grand national 3800 parts or fbody TBs?
  2. #2 Re: bolt on dbc throttle body for l26 intake manifold
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Goodness why are you working so hard. Just run an adapter. So much easier than converting a different TB. Fbody TB's are different bolt pattern as well and 98 or 2000 + is dbw as well.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: bolt on dbc throttle body for l26 intake manifold
    missouri
    Quote Originally Posted by SnowTh1ef View Post
    my ocd won't let me do it any other way. :-(
  4. #4 Re: bolt on dbc throttle body for l26 intake manifold
    Aug 2013
    Sandy, UT
    I feel like your 3rd thought of welding the throttle body to the intake manifold would look much less clean than a simple adapter plate. They look good imo.
  5. #5 Re: bolt on dbc throttle body for l26 intake manifold
    missouri
    i found the solution to all my issues. i found an aluminum intake manifold that uses a cable throttle body and requires no adapter-the l67 intake manifold of course!! i'm gonna do a top swap and forget about all this l26 intake manifold nonsense.
  6. #6 Re: bolt on dbc throttle body for l26 intake manifold
    hangover park IL
    as long as you never upgrade to a gen5 m90....
    ~James~ Psychotic Gearhead
  7. #7 Re: bolt on dbc throttle body for l26 intake manifold
    Mercer, Pa
    I sell the adapter for $80
  8. #8 Re: bolt on dbc throttle body for l26 intake manifold
    hangover park IL
    i made one out of oak plywood
  9. #9 Re: bolt on dbc throttle body for l26 intake manifold
    Mercer, Pa
    Quote Originally Posted by Turbocharged400sbc View Post
    Did you put a light or dark stain on it?
  10. #10 Re: bolt on dbc throttle body for l26 intake manifold
    hangover park IL
    i mixed up two part epoxy and applied it to the microwaved wood so it would soak in on the soft area's. hit it quick with a DA afterwards
  11. #11 Re: bolt on dbc throttle body for l26 intake manifold
    Aug 2013
    Sandy, UT
    lol thats awesome
  1. Throttle body bolt snapped off
    By Dailordasailor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2012, 02:01 AM
  2. Broken throttle body bolt, help!
    By 04gtgp in forum 04+ Specifics
    Last Post: 10-29-2011, 05:03 PM
  3. Throttle body intake questions
    By Dobbs122 in forum General Tech Discussion
    Last Post: 08-01-2011, 11:40 PM
  4. upper manifold/ throttle body removal help!!
    By joshsGT in forum General Tech Discussion
    Last Post: 08-13-2010, 11:30 AM
