Thread: #3 cylinder misfire
Results 1 to 3 of 3
  1. #1 #3 cylinder misfire
    Aug 2012
    Arkansas
    2000 GTP CEL showed misfire in cylinder #3. Plug had a crack in it so I replaced it, all good until a week later and the same problem, same cylinder again. Also have an O2 sensor code now. Could these be related? why would it only affect one cylinder? Maybe the coil pack? I'm goint to switch it with another and see if the problem follows. Any other ideas? Using Autolite XP iridium plugs
  2. #2 Re: #3 cylinder misfire
    O2 code could be a lean or rich condition from the misfire, but I don't know what number the code is.
    I'd start with the coil moving or swap a wire around. Plug wire could be cracked or damaged on the inside.
  3. #3 Re: #3 cylinder misfire
    Aug 2012
    Arkansas
    code is 0141 so its downstream
  1. cylinder 5 misfire
    By hollas13 in forum General Tech Discussion
    Last Post: 01-29-2014, 07:40 PM
  2. Cylinder 3 misfire Tried everything I can think of
    By Beelzeboul in forum General Tech Discussion
    Last Post: 01-27-2013, 09:39 AM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
