Thread: Another Day, Another Engine Code P1406
Results 1 to 2 of 2
  1. #1 Another Day, Another Engine Code P1406
    Aug 2011
    Birmingham, AL
    "P1406 - GM
    Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
    Description
    EGR Valve Pintle Position Circuit Conditions
    Cause
    Engine at idle, then PCM detected these conditions in these tests • Test 1 The EGR sensor input was 0.18v or less • Test 2: The EGR sensor input was 2.06v or higher • Test 3 The maximum change in Desired EGR was less than 0.10v with a signal error over 0.20v for 1 second, or the Desired EGR was 0v with an EGR signal of 0.40v or more, conditions met twice in 10 seconds"
    So...now what?
  2. #2 Re: Another Day, Another Engine Code P1406
    new egr valve time, or bad wires to its plug. sometimes you can clean em out with brake cleaner and free up the valve inside.
  1. Engine code deciphering
    By chuckbattams in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2012, 09:33 AM
  2. Code help after engine replacement
    By rodman918 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 10:41 AM
  3. engine code
    By buckslayer in forum 5.3L V8 (LS4)
    Last Post: 03-16-2011, 09:47 PM
  4. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  5. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
