I have a 98 GTP with the drivers heated seat. I dont think it works. The light on the switch comes on if that means anything. How do i fix it, because the leather is cold in the winter haha.
Well the first thing to do would be to make sure that the fuse is good. If that is okay, then its possible the heating element has gone bad.
if the fuse itself is good. then I would check to make sure the connector under the seat hasnt come loose. If it is still connected... then yes I would say the heating element has gone bad. you might be able to find a new seat from a junk yard car for cheap, or remove the covers on your current one.
