Thread: Need Help with repair
Results 1 to 19 of 19
  1. #1 Need Help with repair
    GT Level Member Xorbex's Avatar
    Canada
    Getting codes p0420 and p0171. Symptoms are of a bad TPS but the car doesnt have one. What is the equivalent of a TPS on an 05.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Need Help with repair
    Oct 2011
    Toledo, OH
    P0420 is low catalytic converter function. P0171 is too lean condition. They are possibly related, look for a vacuum leak.
    How's the car running?
    7"
  3. #3 Re: Need Help with repair
    Canada
    Not at all. Starts then dies immediately. Also before this happened I was getting stuttering/hesitation. And from a stop I was getting a jerk sometimes. Almost as if the tranny was slipping. A google of TPS symptoms basically describes exactly what's happening but the 05s don't have a TPS. I need to know it's equivalent so I can replace it.
  4. #4 Re: Need Help with repair
    you codes lead to a vac leak more then likely.
    http://www.obd-codes.com/p0171
    http://www.p0420.com/ also maybe a chance the cat is clogged up. the check engine light ever flash? car sound like a vacuum with a full bag when you floor it driving, when it ran?
  5. #5 Re: Need Help with repair
    Canada
    It just stuttered when I floored it... No power.
  6. #6 Re: Need Help with repair
    remove the o2 sensor from the rear manifold, then fire it up, see if it stays running.
    this will make a nice exhaust leak, its pre cat so if it runs the cat is clogged up.
  7. #7 Re: Need Help with repair
    Canada
  8. #8 Re: Need Help with repair
    Canada
    Driving on the highway about 55 I was getting weird what seemed like downshifts. Then at stop lights when starting off I was getting a nasty jerk. Also when going wot it was stuttering/struggling. I will try what you asked and see.
  9. #9 Re: Need Help with repair
    a bad maf can cause shifting issues too. un plug it car off, then fire it up see if it runs shifts better, dont go beating on it maf unplugged tho.
  10. #10 Re: Need Help with repair
    Oct 2011
    Toledo, OH
    Also check the vac line that goes to the T under the supercharger snout.
    7"
  11. #11 Re: Need Help with repair
    Canada
    Will do all of that and pull some plugs to see if they got fouled. At work so I'll post back in a few hrs.
  12. #12 Re: Need Help with repair
    your gonna need a 7/8 th o2 socket to remove the o2 if you do that test.
  13. #13 Re: Need Help with repair
    Canada
    Well boys thx for the help. Think I got it, was the maf all buggered because of this https://copy.com/pOM0wBoK9lfvOWA All codes cleared now but I haven't checked it again after a drive.
  14. #14 Re: Need Help with repair
    if you have not cleaned the maf, clean it with maf cleaner only.
    is that broken tube before or after the maf tube? maf tube to intake? or air box to maf tube?
  15. #15 Re: Need Help with repair
    Oct 2011
    Toledo, OH
    That's the MAF to TB hose. The side you don't see has a hole where the PCV valve empties into. That would be your P0171 problem, but you may still have the P0420 come back although a lean condition can cause that too.
    7"
  16. #16 Re: Need Help with repair
    Canada
    All codes are cleared and havent come back after approx 50miles
  17. #17 Re: Need Help with repair
    Does it drive any better?
  18. #18 Re: Need Help with repair
    Canada
    Drives the same as before the problem started.
  19. #19 Re: Need Help with repair
    Oct 2011
    Toledo, OH
    :thumbs up:
    7"
  1. TCC repair\freshening up...
    By Booba5185 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2014, 02:01 PM
  2. Rim repair?
    By mteschGTP in forum Tires & Wheels
    Last Post: 10-07-2013, 11:32 AM
  3. Hud repair on 04+ help
    By Grandprix202 in forum Audio, Security & Visual Electronics
    Last Post: 07-10-2013, 07:56 AM
  4. Navigation Repair
    By carriaga89 in forum Audio, Security & Visual Electronics
    Last Post: 02-23-2012, 04:18 PM
  5. how can i repair this
    By sca555 in forum General Tech Discussion
    Last Post: 10-28-2010, 07:52 PM
