Thread: TCS Stuck Off, DIC Blinks, Left Headlight Blinks, Fogs Don't Work...
Results 1 to 2 of 2
  1. #1 TCS Stuck Off, DIC Blinks, Left Headlight Blinks, Fogs Don't Work...
    Apr 2014
    Maplewood
    Yet another thread for the ol' 2000 GTP. I am having a few electrical issues, and I have no idea the cause.
    1) My DIC blinks intermittently, I'm guessing I should just try to find a new one?
    2) My left headlight flickers in and out while at idle, doesn't seem to really to it while driving...
    3) My TCS is stuck off - this happened after I took the dash apart and ran some gauges, but I traced everything and couldn't find an issue with the wiring with what I changed...
    4) Last but not least, my fog lights don't work - this also happened after I took my dash apart for the gauges.
    I don't really know anything about the electrical side of automobiles yet, so any advice would be much appreciated. Tell me where to look, what to check, and I'll update the thread.
    Electrical mods I know of are as follows:
    I ran a couple gauges, as stated above.
    There was an amp ran to the trunk with some heavy gauge wire that is now just sitting there, and there was some wiring for a gauge face overlay that is a bit convoluted - I'm not exactly sure what they did. The wiring is all located in the area to the left of the gauge cluster, in the little open cubby.
  2. #2 Re: TCS Stuck Off, DIC Blinks, Left Headlight Blinks, Fogs Don't Work...
    Oct 2011
    Toledo, OH
    The TCS problem could be the gauges themselves. I bought a cheap ODBII to USB cable to try out some software. The cable didn't work right (only relaying tach info) and when I unplugged it the TCS turned off and wouldn't turn back on, showing no codes, until I unplugged the battery for a few hours.
    7"
  1. dic blinks numbers then 0's
    By jmitche3 in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2014, 09:33 PM
  2. d.i.c blinks 0
    By alonzo in forum General Grand Prix Discussion
    Last Post: 10-21-2012, 12:17 PM
  3. aeroforce stopped working now blinks red?
    By AmericanSoldier in forum General Tech Discussion
    Last Post: 12-06-2010, 07:56 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Security light blinks
    By Falco in forum General Tech Discussion
    Last Post: 12-01-2009, 10:55 AM
