Thread: 2002 grand prix will not talk to scanner
Results 1 to 3 of 3
  1. #1 2002 grand prix will not talk to scanner
    Aug 2014
    Nebraska
    Hi i'm new here and i am working with a friends grand prix, its a 2002 with a 3.1, To make a long story short he had a used engine installed and now the trans starts in high gear, and it will not communicate with the scanner. I've checked all the fuses, grounds (that i can find) connections and fusible links. I replaced the o2 sensor on the back manifold as it had 3 wires cut. I thought to come here and see if any of you have run into such a problem before. So i will appreciate any ideas you can give me, and if you can tell me the location of all the main grounds so i can make sure they are all there. Once again thanks for any help.
  2. #2 Re: 2002 grand prix will not talk to scanner
    You did check the cig lighter fuse, yes?
  3. #3 Re: 2002 grand prix will not talk to scanner
    Aug 2014
    Nebraska
    the lighter has power yes.
  1. Replies: 184
    Last Post: 03-30-2014, 07:51 PM
  2. 10* of KR on 2002 GT (stock) HPT Scanner
    By acidcrashdburnd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2013, 07:35 PM
  3. Replies: 12
    Last Post: 04-15-2013, 11:18 AM
  4. Any low cost scanner to read 2006 Grand Prix ABS code?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2012, 09:02 PM
