Finally got my SD headers after waiting a few months for them to stock back up. No leaks other than maybe one somewhere around the front header cant tell if its just the exhaust running through the thin piping or a leak. But my main problem right now is my bank 1 O2 sensor, I purchased a 90 degree bung from zzp so it would clear but they are not deep enough the sensor bottoms out before its threaded even half way in. So my fuel trims are all outa whack and O2 sensor is jumping from 120hz to 950, car sometimes stalls. Can I simply just run the bank 1 o2 sensor in the bank 2 location and extend the harness since b2 is tuned out anyways or will this decrease accuracy of the B1 sensor?
