Thread: Gauge cluster+ wheel speed
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
  1. #1 Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Will the wheel speed sensor being unpluged on the passenger side cause the tachometer and speedometer to not be smooth? It doesnt flow smooth and goes up in increments. The passenger wheel bearing is unplugged atm. If not, what will cause that.
  2. #2 Re: Gauge cluster+ wheel speed
    No the wheel bearing being unhooked or bad will not effect either of those items. Since it's both, look for grounds
  3. #3 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    What ground would do it?
  4. #4 Re: Gauge cluster+ wheel speed
    Usually it's just the one that is causing it.
  5. #5 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Its more the tach than the speedo
  6. #6 Re: Gauge cluster+ wheel speed
    I'd check connections at the ICM, crank sensor etc. for starters. If they both are acting up, maybe check the connectors at the back of the cluster.
  7. #7 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Could plug wires do it?
  8. #8 Re: Gauge cluster+ wheel speed
    Tim.. the alignment of the planets might be doing it.
    If you'd like some help, consider taking the advice given, otherwise... go post on FB and see how many off the wall, incompetent posts you can receive with wild suggestions.
  9. #9 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Im saying because I just put the infamous zzp wires on
  10. #10 Re: Gauge cluster+ wheel speed
    Aug 2011
    'Merica
    Put some delco wires on it and see if it changes anything........if not take Bill's advice. You will save some headache and time if you do.
  11. #11 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    I have my old stockers. Ill try it after work. I also just got a tune 2 days ago.
  12. #12 Re: Gauge cluster+ wheel speed
    Your GF's menstraul cycle is causing it
  13. #13 Re: Gauge cluster+ wheel speed
    Aug 2013
    arlington, tx
    ^^^ Hahaha!!
  14. #14 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    So it wasnt the spark plug wires. Wtf
  15. #15 Re: Gauge cluster+ wheel speed
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I would hope not because they shoudnt be related. Its probably a ground like Bill said or your cluster is going out. If you can get a spare cluster I think they just plug right in and see if that helps. Never doubt or question Bill, he will change your name and come to your house and beat you up for questioning his authoritaw.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  16. #16 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Lately all my cluster lights are burning out. Ill just get another one
  17. #17 Re: Gauge cluster+ wheel speed
    Banned
    Feb 2014
    Grand Blanc/ Flint
    Hope I can find one with decently low miles
  18. #18 Re: Gauge cluster+ wheel speed
    Apr 2012
    Dayton, OH
    I have no idea if you can even rebuild them or how too, I wouldnt worry about low miles unless your OCD like that. You still have to keep track of the previous mileage and record it or something for legal reasons if you ever want to sell the car I think.
    2012 F150 STX
  19. #19 Re: Gauge cluster+ wheel speed
    You need a 97 cluster
  20. #20 Re: Gauge cluster+ wheel speed
    Apr 2012
    Dayton, OH
    Damn 97s really are picky arnt they
    2012 F150 STX
  1. Gauge cluster fix???
    By 92GPcoupe in forum General Tech Discussion
    Last Post: 02-28-2013, 06:02 PM
  2. Red Gauge Cluster
    By ShadowSwept in forum General Grand Prix Discussion
    Last Post: 09-09-2012, 04:04 PM
  3. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  4. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  5. Gauge Cluster
    By lstexan in forum General Tech Discussion
    Last Post: 04-23-2010, 11:13 AM
