Thread: Car dies when turning wheel at a stop
Results 1 to 15 of 15
  1. #1 Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    This just started happening recently but at first if I would try to floor it while sharply turning the steering wheel at a stop, the steering wheel would become extremely heavy for a second. Today, something similar happened, where I tried to floor it while at a stop and sharply turning the wheel and my car just died... What can this be?
  2. #2 Re: Car dies when turning wheel at a stop
    Oct 2011
    Toledo, OH
    One of your pulleys is binding up and causing the alternator to slow down.
    Probably your power steering pump.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  3. #3 Re: Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    Why would that make the car instantly die? Even if the alternator stopped working for a second, the battery is still there to provide any electricity. I was reading something about power steering pressure switches possibly causing this on other cars but I couldn't find any replacement power steering pressure switches online so I don't know if our cars have that.
  4. #4 Re: Car dies when turning wheel at a stop
    like he said sounds like something is "slowing" down the engine at idle. bad pulleys on the front of the engine can cause this.
    so take off the belt/ belts you never said what you drive BTW. and check all your pulleys. the a/c compressor can go bad, the water pump, the alt its self. spin them all by hand. if one dont spin freely or feels gritty as turned its bad.
  5. #5 Re: Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    I drive a 2007 base grand prix. That makes sense though, I guess I misunderstood the industrialfish.
    But back to what I was saying, do these cars have power steering pressure switches?
  6. #6 Re: Car dies when turning wheel at a stop
    nope. but if the idle dips down to low the p/s fails to work. feels heavy.
    how many miles on it now? ever do a tune up? the check engine light on? or does it ever flash?
    this used to happen to cop cars in the early 90's iirc, when they would slam on the brakes then try to turn the p/s would quit working due to engine rpm's being to low and cause a lot of cops to crash.
  7. #7 Re: Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    85k miles, no tuneups since I bought it a few months ago but for all I know, it was never tuned up so I'm gonna get on that when I have some time off. No check engine light whatsoever. Only light that comes on is the TPMS one since I put new wheels on it that didn't have the monitors installed.
    You know whats weird, the first time it happened, it was right after braking hard. I had to come to a full stop suddenly and turn and when I tried to turn the wheel it was incredibly heavy for a split second.
    @ Elite6, it only happens from a stop, before actually going through with the turn. It happens when I'm stopped and suddenly turn the wheel and go full-throttle at the same time
  8. #8 Re: Car dies when turning wheel at a stop
    Cambridge, Ontario Canada
    Have you looked to make sure nothing is in contact with the PS pulley/belt when doing a sharp turn? Does it run fine in a straight line or doing a normal turn?
    2005 E55 - stock
  9. #9 Re: Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    So, a little update since I had time and an extra set of hands to help diagnose this:
    I had someone turn the wheel all the way for me while I watched the belt/pulleys and I noticed that a tensioner seems loose/seizing up. By this, I mean that it makes a noise as soon as it tension is applied to it but it seems loose in that whenever tension is applied, it tilts a bit.
  10. #10 Re: Car dies when turning wheel at a stop
    Oct 2011
    Toledo, OH
    There ya go. Tensioner is bad. Around $35 for the tensioner with pulley, and one bolt to remove it after you take the belt off.
    7"
  11. #11 Re: Car dies when turning wheel at a stop
    Mar 2014
    SE PA
    Thank you much, good sir!
  12. #12 Re: Car dies when turning wheel at a stop
    this has to be the tensioner on the alt bracket. its not 35 bucks by a long shot, closer to 75 even on line.
    the pulley can be changed thats 20 bucks. but if the tensioner was bouncing all over its bad.
  13. #13 Re: Car dies when turning wheel at a stop
    Oct 2011
    Toledo, OH
    Holy crap, I didn't even look at specifics for the part, just going off knowledge of changing tensioners for 20 years. That is pretty pricey, and isn't just a simple pulley on a spring like most are.
    Maybe check to see if any of the bolts are loose first and letting it flex. Also it could be just the pulley, binding up and putting a lot of stress on the tensioner.
    7"
  14. #14 Re: Car dies when turning wheel at a stop
    http://shop.advanceautoparts.com/p/d...Term=tensioner of cousre they are cheaper with a code, or else where, but yeah, not cheap at all.
  15. #15 Re: Car dies when turning wheel at a stop
    the tensioner dont come off the alt bracket, (need to get a new/used alt bracket)
    i need one too. my pulley's bearing has worn the nub it rests/seats on away. so now the pulley sits loose on it. still works, but squeaks a bit at first start up of the day. then it goes away.
    times like this i wish i have a good you pull it.
  1. popping when turning wheel
    By gxp revenge in forum Brakes/Suspension/Chassis
    Last Post: 06-04-2014, 04:57 PM
  2. Creaking when turning wheel
    By Ultra440 in forum Brakes/Suspension/Chassis
    Last Post: 08-10-2013, 01:08 PM
  3. Clunking noise when turning wheel?
    By Hippo Machine in forum General Tech Discussion
    Last Post: 09-16-2012, 02:02 PM
  4. Clunk while turning steering wheel
    By Z28 in forum General Tech Discussion
    Last Post: 03-31-2011, 12:57 PM
  5. Loose power or bogg turning Left from stop
    By Sykkel in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2009, 06:07 PM
