Oh I meant to say they recommend the 180*
Sent from my SCH-I545 using Tapatalk
Only thing a 180 will do for you is make the engine less efficient. If you'd like to drop a couple miles per gallon...that's your mod.
See why I haven't mentioned it in the past.
Ok guys, my cart on Rockauto.com consists of the following:
FelPro LIM gasket set (MS98014T)
FelPro Valve cover gasket w/ grommets (VS50465R)
FelPro Plenum upper gasket (MS95744)
FelPro throttle body gasket (61024)
6x ACDelco Injector o-rings (19238128)
Dorman Aluminum Coolant Elbows
195* tstat
Am I missing anything???
Yes they are Joe.. they have a T at the end of the part number.
You will also want 4 cans of brake cleaner, a gasket scraper/razor blade, shop rags, oil and oil filter, coolant (2 gallons concentrate) and teflon ptfe sealant for the threads on the LIM bolts.
2 per each injector and they come with 4 in a pack so 3 packs...3x4 = 12 lmao so yea your correct
Quick question: I need to go buy sockets for my torque wrench. The only size of bolts that need torque spec are the LIM (3/8" )and SC (10mm?). Correct?
I dont know because I haven't done the LIM yet but I would get a set of metric and standard might be a little cheaper but depends where you go plus you have other sizes andnya never know when you could use them.
Sent from the Milky Way
