Thread: Leaking gaskets need diagnosed (with pics)
Page 3 of 12 FirstFirst 12345 ... LastLast
Results 41 to 60 of 228
  1. #41 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Oh I meant to say they recommend the 180*
    Sent from my SCH-I545 using Tapatalk
  2. #42 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    don't go 180....ever.
  3. #43 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    unless you tune for it, then again unless your heavily modded I wouldn't bother
  4. #44 Re: Leaking gaskets need diagnosed (with pics)
    Only thing a 180 will do for you is make the engine less efficient. If you'd like to drop a couple miles per gallon...that's your mod.
    See why I haven't mentioned it in the past.
  5. #45 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Haha alright. Thanks guys
  6. #46 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok guys, my cart on Rockauto.com consists of the following:
    FelPro LIM gasket set (MS98014T)
    FelPro Valve cover gasket w/ grommets (VS50465R)
    FelPro Plenum upper gasket (MS95744)
    FelPro throttle body gasket (61024)
    6x ACDelco Injector o-rings (19238128)
    Dorman Aluminum Coolant Elbows
    195* tstat
    Am I missing anything???
  7. #47 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    you need a 195* tstat not the 180*
  8. #48 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    No idea why I put 180. Good catch
  9. #49 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    LIM gaskets the metal kind? If they are not get the metal kind
  10. #50 Re: Leaking gaskets need diagnosed (with pics)
    Yes they are Joe.. they have a T at the end of the part number.
    You will also want 4 cans of brake cleaner, a gasket scraper/razor blade, shop rags, oil and oil filter, coolant (2 gallons concentrate) and teflon ptfe sealant for the threads on the LIM bolts.
  11. #51 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    How many o-rings do I need? Assuming 12.
  12. #52 Re: Leaking gaskets need diagnosed (with pics)
    2 per each injector and they come with 4 in a pack so 3 packs...3x4 = 12 lmao so yea your correct
    04 Comp G.
  13. #53 Re: Leaking gaskets need diagnosed (with pics)
    Enfield, CT
    Also get a new radiator cap and take the old one and throw across the street....
  14. #54 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Is one of these the heater inlet hose that I need to splice for the coolant flush kit?
  15. #55 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by highoctaneracing View Post
    Your rad cap kick your ass lol?
    You don't need a flush kit, scotty will probably post soon on how to flush the cooling system.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  16. #56 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok. I have a flush kit to use unless there is an easier way. I talked to BillBoost and he has another way of doing it too
  17. #57 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Dayton, OH
    Found his post
    how to flush the coolant.
    remove the t stat, put the t stat housing back on, take the upper hose off the radiator, then push it down to the ground to a bucket or let it fly.
    get your garden hose out, put it in the rad turn it on, then fire up the car, let it run till clear water pumps out the top hose.
    then turn the hose off, run the car till no more water comes out the upper hose. then turn it off.
    put your t stat back in, with new gasket, the upper hose back on.
    now take 1 gallon of full strength green antifreeze, not the 50/50 crap. ( parts store cheap green is fine to use) dump the whole gallon in the radiator, fire up the car, fill the rad with hose water till its full. top as needed till its ready to be bled of air. it will burp and take coolant as the water in the block warms up the t stat opens up for a few seconds till cold coolant hits it and it shuts again.
    now to bleed the air out, let it idle rad cap off till the fans turn on, (when the fans are on the temp is over 195 deg, the t stat is wide open) then open the bleeder screw on top the t stat housing a few turns till a steady stream of coolant comes out the hole, shut the screw, top off the rad. cap it.
    done.
    2012 F150 STX
  18. #58 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Quick question: I need to go buy sockets for my torque wrench. The only size of bolts that need torque spec are the LIM (3/8" )and SC (10mm?). Correct?
  19. #59 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Dayton, OH
    I dont know because I haven't done the LIM yet but I would get a set of metric and standard might be a little cheaper but depends where you go plus you have other sizes andnya never know when you could use them.
    2012 F150 STX
  20. #60 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Alright thanks man!
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
