Thread: Leaking gaskets need diagnosed (with pics)
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 21 to 40 of 228
  1. #21 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Wow seems very doable now. I did notice you didnt mention anything about removing spark plugs/wires. Does that need to be done?
    Sent from my SCH-I545 using Tapatalk
  2. #22 Re: Leaking gaskets need diagnosed (with pics)
    You need to undo the rear 3 wires at the coils and flip them onto the cowl... that's it.
  3. #23 Re: Leaking gaskets need diagnosed (with pics)
    I simplified a bit. You are going to find a vacuum line and nut or two I left out.. Those are things my hands do w/o thinking.. well ... most of the job acutally, but I've done it once or twice.
  4. #24 Re: Leaking gaskets need diagnosed (with pics)
    little extra tip i did when i did my lim.
    remove the dog bones, remove the lower rad hose from the timing cover, let it drain, then push the engine to the firewall and then back to the rad, you'll see more coolant come out when its pushed back and fourth.
    now when your ready to pull the lim off, break the plastic elbow so its not a fight, and then lift the lim off as level as possible so no coolant leaks out of it.
    the cooling ports on the lim have a small lip that will hold some coolant in the lim still, rocking the engine back and fourth gets rid of a lot of it. when i took mine off, not a drop spilled and i didnt do a oil change when i was done.
  5. #25 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok I'll try that to. I'm gonna go ahead and order everything tonight. I plan on it taking me a couple days going at a slow and careful pace.
  6. #26 Re: Leaking gaskets need diagnosed (with pics)
    you can do it all in a after noon. its not hard. once the fuel rail and wire harness are off its all easy.
    did mine in like 3 hours. first time doing one on a 3800. hardest part was cleaning off the old upper plenum gasket (aka blower gasket) off the lim and blower.
  7. #27 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Yea definitley seems really easy once I get everything unplugged and what not. Just unbolting stuff from there on.
  8. #28 Re: Leaking gaskets need diagnosed (with pics)
    See....we told you.. it's easy
  9. #29 Re: Leaking gaskets need diagnosed (with pics)
    from this.
    to this in about a hour or so.
    before you start the lim job go buy some new vac line and T's cause those are gonna break. the fat hose off the TB may also break.
  10. #30 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    The vac lines will break?
  11. #31 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    Quote Originally Posted by 2FASTGTP View Post
    Yep. Just ask CpnBreakAlot............
  12. #32 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Haha at least theyre easy to replace
  13. #33 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by Below Average Joe View Post
    He also fried his ICM wiring and killed a battery on his 2nd LIM gasket attempt
    2012 F150 STX
    - Gonna be a race truck
  14. #34 Re: Leaking gaskets need diagnosed (with pics)
    the T's will break. so you need new T's one for the fpr, one for under the snout.
    you can replace most of the hard lines if you want to, or cut the old ends off the heard lines, then cut 3, inch and a 1/2 long pieces of vac line to put on the T, then push the hard lines into the vac line on the new T.
    this was my old factory line from the front of the engine. bbp valve, to fpr, to under the snout line. i replaced it all.
    best T's i could find local was at advance auto. they have a whole section of vac T's and parts. they have these small white T's 2 in a pack for 2 bucks. best T's around. vac line is sold by the foot. i did most of my engine with new line and the t's for 5 bucks.
  15. #35 Re: Leaking gaskets need diagnosed (with pics)
    now lets not scare the guy now. capt breaks everything, we are not all like that.
  16. #36 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    How much additional work is it to replace the water pump and tstat?
  17. #37 Re: Leaking gaskets need diagnosed (with pics)
    Water pump will be super accessible. You'd need to yank off the SC idler pulley, lower the power steering pump (2 bolts that you can't see), then it's 4 13mm bolts, 4 or 5 10mm bolts and a gasket cleaning. Honestly though..I've seen water pumps last into the 300K mark on these cars. The pump will go bad when it will. A new one can do the same.
    T stat is two bolts in the housing on the LIM. Literally a t stat change takes 5 min on the car with it fully assembled. You pop hood, undo two 10mm bolts, pull up on it.. clean the surfaces, pop the new one in and put the housing back on. I leave the hose on it and all. Two bolts is all I do. Then check your coolant level...cause you let out about 4 cups.
    As for capnbreakitall... he obviously wasn't paying full attention and sandwiched wiring in the process. I'll tell you honestly .. I can't imagine how that happened... I've done these things slowly, fast, drunker than drunk and all kinds of sleep deprived. Never could i pull that off.
  18. #38 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok i'll just do the tstat and not the pump then. Some people recommend a 195* tstat is that right?
  19. #39 Re: Leaking gaskets need diagnosed (with pics)
    Aug 2011
    'Merica
    Yes
  20. #40 Re: Leaking gaskets need diagnosed (with pics)
    Which....is already in your motor
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
