Thread: Leaking gaskets need diagnosed (with pics)
Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 228
  1. #81 Re: Leaking gaskets need diagnosed (with pics)
    Feb 2013
    37.295091, -121.930053
    .... that is what scotty was talking about
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  2. #82 Re: Leaking gaskets need diagnosed (with pics)
    correct. off the engine.
    the lower rad hose off the rad is a pita to get off for real lol i just had to change my rad. what a ordeal the lower hose was. i should have changed that damn hose on general principals lol
  3. #83 Re: Leaking gaskets need diagnosed (with pics)
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Whats the trick to disconnecting this badboy?
    Sent from my SCH-I545 using Tapatalk
  4. #84 Re: Leaking gaskets need diagnosed (with pics)
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Pull the white pin out then it comes off like normal connectors
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  5. #85 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Got everything unplugged and disconnected now, do I need to do anything with the circled part in the pic? And does I highlighted need to be moved somewhere?
  6. #86 Re: Leaking gaskets need diagnosed (with pics)
    take the fat hose off the top off and the small line to the fire wall off. the small line its best to cut the old rubber end then remove it as the tree likes to break. then use a new 1 inch of vac line to put it back on later.
    you need to un hook the evap back theres still, and the map if its not done yet.
    the harness there will lift up some more after its all unhooked, then lift and slide the blower out from under it.
    you need to take the tb cables off too.
    dont forget the egr tube on the driver side of the lim, is one bolt.
  7. #87 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Here's how things are looking right now back there. Do the EGR and MAP need unbolted anywhere?
  8. #88 Re: Leaking gaskets need diagnosed (with pics)
    i hope you dont need this car come monday lol this is taking a long as time.........this is a 3 hour job most of the time.
    the evap, the one with 2 vac lines, the black side pulls off, the white side you pinch and pull it off.
    the map sensor has a vac line under it, unbolt it and remove the vac line. pretty sure its held down via 2 super charger bolts.
    the egr valve can stay put, the tube from it to the lim needs to be unbolted, and pulled from the lim.
  9. #89 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Ok yeah I don't need it anytime soon thats why I'm just going slow and careful
  10. #90 Re: Leaking gaskets need diagnosed (with pics)
    Looks good so far.
  11. #91 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    For the removal of the alt bracket, I found one 15mm bolt under the pulley but where are the other 2?
  12. #92 Re: Leaking gaskets need diagnosed (with pics)
    see three holes now?
  13. #93 Re: Leaking gaskets need diagnosed (with pics)
    That back one will trip up a first timer for sure.
  14. #94 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Got it off. The lim is not budging to come off though.
  15. #95 Re: Leaking gaskets need diagnosed (with pics)
    You need to remove 12 LIM bolts. Nab a picture of the Engine as it sits.
  16. #96 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Also, before I pull the LIM off I wanted to ask if its ok to put a towel over the crank to avoid pieces of gasket being scraped into it?
  17. #97 Re: Leaking gaskets need diagnosed (with pics)
    Front lower right of the picture. Next to the T stat hole. Is that lower bolt down in that gully. There should be two bolts taken out right there.
    Yes..you can put a towel over anything you'd like.
  18. #98 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Scraped LIM free of most debris. Now do I go at it with brake cleaner or what?
  19. #99 Re: Leaking gaskets need diagnosed (with pics)
    Scrape it flat .. like you have. Then you clean any residual dirt/grime off with a rag and brake cleaner. Expect that the image of where the gasket was...will show up. Once the rag is clean..you are all set. The old gasket shows up with cleaning though..it always happens.
    Soooo was I right?
  20. #100 Re: Leaking gaskets need diagnosed (with pics)
    Apr 2012
    Indiana
    Yeah you were right! So same procedure with rag and brake cleaner on the mating surfaces in the engine? I should do valve cover gaskets before all this right?
  1. *Pics* Where is my Oxygen sensor and what could be leaking?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:39 PM
  2. Antifreeze leak - Still Leaking - Not LIM - New Pics Sept 29 2012
    By heavydtheogre in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2012, 04:10 AM
  3. Coolant leak: Diagnosed and fixed
    By BillBoost37 in forum General Grand Prix Discussion
    Last Post: 02-06-2012, 07:18 AM
  4. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  5. Valve cover gaskets leaking
    By PTGsDaytona500GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 11:11 AM
