I keep getting this code. Could it be my O2 sensor? Car drives normal.
Sent from my PantechP8010 using Tapatalk
Usually this is a vacuum leak somewhere. I've been fighting this code for a while now too, and my car drives fine as well. Replaced my upstream 02 (was old as whatnot, so figured it was time anyways), and still have the code. No vac leaks that I can find. I've even pulled the EGR tube and found it to be airtight, and sealed both ends. I think I'm about to have it smoked to see if I have a leak somewhere that I can't find. Tired of the damn CEL.
Ya, it's been coming on and off for awhile and actually when it came on today, I just did the egr block off with a dime and quarter and the quarter moved so I just put the egr valve back on. Possibly I didn't tighten it enough? I cleared the code, drove for a good 20 miles today and it came back on so I'll probably have to just try to tighten it down real good. Also my boost gauge reads normal vacuum as well.
I have also seen corroded battery cables cause this issue.
This should not be an O2 sensor.
Well I tightend my egr stuff and double checked my vac lines and they seem good. So like Fordman, I will probably have to get a smoke test done cuz everything looks good and tight. Hope it's not my LIM gasket :/
BTW, I smoke cigs so could I actually do my own smoke test by blowing my cig smoke through a line? Also what line would be best?
Pretty sure I had this code after working in the car a few years back. I had the MAF unplugged during the work. After getting the code, I unplugged the MAF, re-plugged it, and the code was gone.
Dont forget an exhaust leak before o2 can cause the code too.
I think I figured it out. I'm pretty sure it was my egr tube to the intake that was bent up a little. I deleted my egr today and so far the code hasn't come back after a good 30 mile drive.
I think it's good. I'll have to keep an eye on it.
I had this code a while but after a good MAF cleaning I haven't seen it once...
