Thread: misfire woes
Results 1 to 5 of 5
  1. #1 misfire woes
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    Ok I tried doing some searching but I couldnt find and exact scenerio like mine. Anyway here we go, I had a misifre code saying misfire in cylinder 2. My plugs and wires are new(ac delco pro iridiums, moroso wires). checked the plugs anyway, they look good. I switched the coilpack with the one below it. I then got a multiple misfire code. my car is a 01 gtp with catted dp and intake and 87000 miles.
    p.s. this may not make a difference but i like to give best description, but i have a bad exhaust leak. I mean settin car alarms off bad. (hole between the cat and resonator.
    thanks
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  2. #2 Re: misfire woes
    SE Level Member presser's Avatar
    cinci, oh & sterling hgts, mi
    Try swapping coil packs to rule those out. Listen to your #2 injector - it should tick like the others. You can use a broomstick or similar long pipe and hold it to your ear if you don't have a steth.
    If neither is bad then take it to the dealer unless you care to remove the valve cover and replace your broken valve spring (my guess).
  3. #3 Re: misfire woes
    Well like I said, I switched the coil pack for cylinder 2 with the coil pack below(I think its 4 and 1) and thats when I got the multiple misfire code.
  4. #4 Re: misfire woes
    I'd move it with another coil and see what happens.
    I'd say either a coil is bad or the ICM under the coils is at fault.
  5. #5 Re: misfire woes
    Perplexing...Are you absolutely certain you connected your plug wires correctly to the coil packs?
    Just double check - Because it happens.
  1. Alternator woes?
    By Bigjoe980 in forum Introductions/Noob Questions
    Last Post: 06-02-2013, 01:58 PM
  2. MAF sensor woes
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 01-09-2013, 01:38 PM
  3. Window Woes
    By MrPhotographer06 in forum General Tech Discussion
    Last Post: 02-18-2011, 12:32 AM
  4. computer woes
    By Biohazed in forum Off Topic Discussion
    Last Post: 07-13-2010, 04:59 PM
  5. Subscription woes
    By Preotic in forum Off Topic Discussion
    Last Post: 02-01-2008, 07:28 AM
