Thread: Cold Start Stalling
Results 1 to 6 of 6
  1. #1 Cold Start Stalling
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    Hey everyone,
    My car has always had an intermittent problem with starting. Sometimes it will start normal and sometimes I have to gas it for 5+ seconds to keep it running. It seems to be happening when the engine is cold, when the engine is warm this problem rarely happens.
    I have cleaned the throttle body, changed plugs and wires, cleaned IAC valve, cleaned MAF, fresh filter, and pcv valve. I do not have vacuum leaks.
    I'm thinking even thought I have no DTC's I should replace the IAC valve. Should that be the next step?
    Thanks in advance.
  2. #2 Re: Cold Start Stalling
    Step 1: Please educate us on what you drive. Currently..I assume Yugo
    Step 2: Unplug maf with ignition off, start car a few times until the pcm seems to have learned and is running well. Then tell us if that makes it start better overall.
  3. #3 Re: Cold Start Stalling
    Medford, NY
    i thought i had a signature. it's an 03 gt. Step 2 didn't affect the way it starts. I started it about 10 times and let the idle smooth out but each time I had to put my foot on the gas to start it.
  4. #4 Re: Cold Start Stalling
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    do you have good fuel pressure? does it hold the pressure or does it drop off to nothing pretty fast after running? codes?
  5. #5 Re: Cold Start Stalling
    Medford, NY
    it holds the pressure, don't know if it's "good" pressure. No codes. I just replaced the IAC valve for 21 bucks and so far it seems to have fixed it. I'll have to update again tomorrow because the car may just be too warm now.
  6. #6 Re: Cold Start Stalling
    Medford, NY
    starting up just fine now... looks like IACV was the culprit
  1. RE: Stalling @ startup (cold only)
    By pbxcomm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2012, 07:54 PM
  2. Replies: 1
    Last Post: 02-08-2012, 10:09 PM
  3. Overkill PCM now Stalling rough start
    By kyleinkman in forum PCM Tuning
    Last Post: 10-25-2011, 07:26 PM
  4. Rough Start/Stalling Issue
    By Bigg Dogg in forum General Tech Discussion
    Last Post: 08-18-2011, 07:08 AM
  5. 97 GTP - Rough idle, stalling after start?
    By Psyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:08 PM
