Thread: Installing New PLOG Exhaust Manifold - Help
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Installing New PLOG Exhaust Manifold - Help
    May 2012
    Where winter never ends
    Yeah when I did my header install ,I just went at the bolts with a breaker bar to break em loose and then took an air ratchet to take em off. I just cut the crossover ones because im lazy, and I just cut the egr out again because I am lazy. Same with the DP bolts and Cat back bolts. Rusty bolts make me use a grinder and just spend the dollar or two on new ones.
    2000 Regal - Winter Beater
  2. #22 Re: Installing New PLOG Exhaust Manifold - Help
    YOu guys make it sound hard. I use a ratchet, maybe an air ratchet. Quick easy ...done
  3. #23 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    Quick question.. What is the size of the bold that connects the cross-over pipe the the em? Also, what is the torque spec for the exhaust manifold studs/nuts, and the cross-over pipe?
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  4. #24 Re: Installing New PLOG Exhaust Manifold - Help
    10mm and a 13mm I think.
    Torque spec is tight, very snug.
  5. #25 Re: Installing New PLOG Exhaust Manifold - Help
    Both times I installed headers only bolts I broke were the bolts on the crossover, and I just used a standard 3/8 drive ratchet to take out the manifold bolts. And both times I reused the bolts.
    Sent from A Galaxy Far Far Away........
  6. #26 Re: Installing New PLOG Exhaust Manifold - Help
    There's no 10mm in what you are going at..
    Crossovers are 13mm
    Exhaust bolts are 13mm
    The bolts/nuts that hold on the engine lift bracket are 13mm
    Plugs.. those are the smaller plug socket. (yeah..that's right, I don't know the size..lol)
    In the amount of time I've typed to this thread..I could have done the job.
    Sorry.. IDK the torque spec, there is a thread for that though. I go tight.. but not bolt snapping tight.
  7. #27 Re: Installing New PLOG Exhaust Manifold - Help
    Apr 2014
    Minneapolis
    I got the manifold on and the car runs perfectly. Thanks again for the advice guys!
  8. #28 Re: Installing New PLOG Exhaust Manifold - Help
    Did you break anything?
  1. Flow numbers Stainless PLOG and ported front exhaust manifold
    By usetaboost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2013, 10:10 PM
  2. Installing PLOG on 99 GTP
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2012, 05:40 PM
  3. need some help installing an exhaust
    By asite57 in forum General Tech Discussion
    Last Post: 07-23-2012, 12:42 PM
  4. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  5. plog and ported manifold
    By superv6 in forum General Tech Discussion
    Last Post: 05-08-2009, 06:34 AM
