Thread: Question about filling motor/trans mounts.
Results 1 to 8 of 8
  1. #1 Question about filling motor/trans mounts.
    Pennsylvania, USA
    So while I had my subframe lowered to get into my transmission (thanks again for writing that guide Bill), I saw my motor mount has finally started to leak and sag a little. I have some new hydraulic mounts that I drilled a while back and forgot about, and now is about time I filled them.
    I originally was going to fill them with that window weld stuff like I've seen in a thread before, but it's supposed to cure to a shore rating (hardness) similar to polyurethane mounts. I'd rather fill them with something closer to the rubber the mount is made of though so they still have some give.
    Does anyone know what could be used to achieve this? I'm almost thinking black RTV would work, but I'm not sure what shore number I'd really want to aim for.
    And how long should I let them cure? Some threads on other forums have said 24 hours is enough, but I've also seen some people say up to a month.
  2. #2 Re: Question about filling motor/trans mounts.
    hangover park IL
    The window weld takes a couple weeks and the rtv takes a few months
    if neither is fully cured then you end up with a spaghetti maker when you put the motor down on it
    ~James~ Psychotic Gearhead
  3. #3 Re: Question about filling motor/trans mounts.
    Pennsylvania, USA
    Wow, that's a long time to wait for a mount. I'll just have to bite the bullet and wait until summer to put them in. I don't want to take a chance of having vibrations when I'm stuck in traffic, the blown mount is already bothering me a little.
  4. #4 Re: Question about filling motor/trans mounts.
    hangover park IL
  5. #5 Re: Question about filling motor/trans mounts.
    I don't know how good the quality of them are but Partsgeek has solid engine mounts for ~$30.
  6. #6 Re: Question about filling motor/trans mounts.
    hangover park IL
    No "solid" mounts are solid...they are hollow with air instead of oil/ water...so they collapse fast as ****.
    there really isn't much difference between RTV and the urethane
  7. #7 Re: Question about filling motor/trans mounts.
    May 2013
    illinois
    i had a zzp solid trans mount and ripped it in half in less than 1000miles
  8. #8 Re: Question about filling motor/trans mounts.
    hangover park IL
    ...and I've had brand new ones collapse and settle onto the cross pin.....now that will give you a vibration to complain about....
  1. WTB ZZP Billet/Polished Dog Bones, Poly Motor, Trans Mounts
    By GrandPrix06GT in forum Wanted To Buy - Parts
    Last Post: 03-19-2014, 08:43 PM
  2. Question about hard shifts, trans mounts and additives
    By comatoast in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2013, 06:33 PM
  3. Bad halfshaft or bad motor and trans mounts?
    By GRAND98 in forum General Tech Discussion
    Last Post: 08-18-2012, 05:27 PM
  4. Motor mounts
    By Chizzler in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2010, 08:13 PM
