Thread: Safe RPM Limits??
Results 1 to 12 of 12
  1. #1 Safe RPM Limits??
    TDCRacing
    Guest
    I Will have about all I can to help with oiling such as the Intense oil pressure kit,Balance shaft removed and plugged,Oil return holes drilled ect ect.
    I am hoping to get some input from you turbo guys since i'm sure you guys are the main ones that are running high rpm's. But anyone who knows i'd also like you're opinion.
    My cam's power range will be from about 3500 to 7500. Or so it says.
    So i'll likley be shifting around 7500.
    It will also be a fully rebuilt motor.
    What i'm mainly wanting to find out is What the title says. What is safe as in if I do it a lot will it reduce my motor life by an EXTREAM amount?
  2. #2 Re: Safe RPM Limits??
    TDCRacing
    Guest
    I see now that most turbop camshafts rpm range is under 7000.
  3. #3 Re: Safe RPM Limits??
    Oklahoma
    Will the valvetrain hold up to 7500 rpm?
  4. #4 Re: Safe RPM Limits??
    TDCRacing
    Guest
    I plan to have all the nessary upgrades like roller rockers,lighter tiatainum retainers and locks,3/8 push rods ect ect.
    But I guess that's what i'm trying to find out.
    I'm considering going turbo at the moment. Just not sure if I want to wait as long as it will take to save up the money and all.I have to check on a gtp that my buddy has for sale for like a 1000.00 bucks. Runs and drives and in pretty good shape.Just have to make sure that he still wants to sell it and all. That is what will make the decision for me more than likely.
    That way i can have a dd on the side and take my time with this one.
  5. #5 Re: Safe RPM Limits??
    Barksdale AFB, LA
    I hope you're going to get lifters, too. I'd be worried about one collapsing at such high RPMs.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Safe RPM Limits??
    TDCRacing
    Guest
    yep for sure...even if i do go turbo.
  7. #7 Re: Safe RPM Limits??
    SE Level Member 2001camaroB4C's Avatar
    7500 is a lot of rpm. I also have an ls1 car and wouldn't shift that anywhere near that high. You would need some high rpm lifters idk if you can get a solid lifter setup for a 3.8 but that wouldn't collapse. Some intense pushrods. And equally intense valve springs. Roller rockers. And can the bottom end handle spinning that kind of rpm?
    But I dont really know a lot about these motors.
  8. #8 Re: Safe RPM Limits??
    TDCRacing
    Guest
    Well for what it's worth I have known manny people that have had 302's and with a cupple of oiling tricks spin to 8000 no problem,consistantly at the track all of the guys that I know have had many many track passes and have yet to have a problem spiining that high or have a problem from spinning that high.
    I understand this is not a 302 but I think the general concept is the same.
    But that's what i'm trying to find out.
  9. #9 Re: Safe RPM Limits??
    I live here. UR LOSN's Avatar
    Rockford, IL
    the stock ignition system starts to break up at 7000..... I wouldnt trust it much past that.
    If it is a built motor... what kind of bearings were you going to use?
    I would STRONGLY recommend some along the line of an "H" bearing... but if this is primarily a track car.. I would go for more of an "HX" bearing... these are made for high RPM, and offer better cooling.
    get the best money can buy. dont skimp. otherwise you will be rebuilding it often.
  10. #10 Re: Safe RPM Limits??
    TDCRacing
    Guest
    Quote Originally Posted by UR LOSN View Post
    Ok thanks for the input. I was planning on using something along those lines. I noticed on intenses website that I belive it was that hx bearings stated to only use in a track only car.Why is that?
  11. #11 Re: Safe RPM Limits??
    Donating Users chrisb's Avatar
    Bucyrus, OH
    [QUOTE=UR LOSN;115288]the stock ignition system starts to break up at 7000..... I wouldnt trust it much past that.QUOTE]
    i think 7100 is the limit on the stock ignition. not sure with what you could upgrade it with?
    what psi are you going to set the oil pressure at?
    have you looked into a new balancer? i believe stock is good up to 6300 after that you could be hurting the motor. zzp says going over that can cause bearing failure.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  12. #12 Re: Safe RPM Limits??
    TDCRacing
    Guest
    You could always go with a dis-4 from msd. The oil pressure will suposedly be at 80 - 85 psi with 20w50.
    I have not looked into a new ballancer but planned on getting an sfi one to go along with the build.
  1. Determining Safe Pulley Size with L67 & M90 [*]
    By gmboy in forum How To Write-Ups/Tech Tips
    Last Post: 06-18-2010, 11:56 PM
  2. Is it safe to coast in Neutral?
    By DesQ27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-08-2008, 10:39 AM
  3. This looks like fun & safe
    Last Post: 06-29-2008, 09:13 PM
  4. what limits boost
    By deangtp in forum PCM Tuning
    Last Post: 04-08-2008, 03:53 PM
  5. Picture Limits
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 12-17-2007, 01:26 AM
